Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Mid-west USA
Mid-west USA Local discussions for those on the Mid-West US. ( Minnesota, Iowa, Wisconsin, Michigan, Illinois, Indiana, Ohio, Nebraska, North Dakota, South Dakota, Kansas, Missouri)
Old May 25th, 2016, 12:14   #7501
SpamJ
SpamJ's Avatar
Fuel Economy: 52/45/30
Stolen from his garage in Woodbury.
Sam
02 TDI Jetta Wagon
Not Insane
SpamJ is offline   Reply With Quote
Old May 25th, 2016, 13:07   #7502
JFettig
JFettig's Avatar
Woodbury
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old May 26th, 2016, 21:38   #7503
Merchlewitz
People really have to have some balls to steal a car from a garage... That's sad.. Curious Chris and I have been busy doing some fixing on the 02 Jetta I bought.. So far Brakes rotors all around + starter. We are working on doing the suspension now.. got front left strut replaced, passenger side to go with back shocks and springs!
Gotta admit Chris is pretty knowledgeable when it comes to TDI's!
Merchlewitz is offline   Reply With Quote
Old May 27th, 2016, 10:25   #7504
tango_28
tango_28's Avatar
Will keep on eye on that stolen Audi.
03 TDI Jetta Wagon
06 LTD awd Freetstyle wagon
tango_28 is offline   Reply With Quote
Old May 28th, 2016, 06:24   #7505
1st_TDI:)
1st_TDI:)'s Avatar
Fuel Economy: 39.5-49 mpg (best day)
Default Brass car theives
Was on the road all day yesterday from Park Rapids to Watervillie, just short of 600 mi.
Did not see a Blue Wagon.
Turned 275k on clock near Motley.
1st_TDI:) is offline   Reply With Quote
Old May 29th, 2016, 19:55   #7506
Curious Chris
Fuel Economy: 47/42/38
Originally Posted by indigoTDI View Post
Also, I'm getting a lot of noise from the rear passenger wheel - pretty sure the bearing is going. How tough are they to replace? (intact the whole suspension is getting pretty weak and the front is making a slight clunking when at a full turn) yeah, it's time to move on...
Hopefully it is the rear bearing. I had a clunk over bumps in my car and it was the trailing arm bushings. VW says they are not replaceable and that is close to true but I replaced mine. I have the insertion tool that worked very nicely. I also have the tool to press the rear bearing in.
Curious Chris is offline   Reply With Quote
Old June 1st, 2016, 17:24   #7507
Farmboy
Default 2000 Beetle 1C0831411B lower hinge left door
2000 Beetle 1C0831411B lower hinge left door . . . anyone happen to have one they are looking to part ways with quick and easy like?
Broke both bolts off at the door with minimal effort applied . . . likely will drill out, tap, and use different bolts, just thought I'd do a quick check first . . .
Often willing to "pay it forward" & encourage others to do the same . .
Farmboy is offline   Reply With Quote
Old June 1st, 2016, 21:18   #7508
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Sorry, no junk beetles kicking around.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old June 2nd, 2016, 05:50   #7509
Redlabel6
Redlabel6's Avatar
Fuel Economy: A3 51mpg, B5.5 38mpg
Hey Tom,
U-Pull-R Parts in East Bethel shows 2- 2000's and a 2002 Beetle in their inventory, no Yellow ones, two silver and one green. There is a Blue 1999 one in Rosemount too.
http://www.upullrparts.com/inventory
David
05 Passat GLX TDI Stonehenge Gray
05 Jetta 2.5 Gasser
73 Karmann Ghia Autostick
Redlabel6 is offline   Reply With Quote
Old June 3rd, 2016, 18:54   #7510
Stan TDI
Looking for a front bumper cover and grill for a white 2001 Jetta. If anyone knows where to find one, it would be much appreciated. White is not very common.
Also will have left over parts from the 2001 project. Stuff like, head including injectors, race pipe, block but likely bent rod as it hydrolocked, 10mm injection pump, injector lines (the hard ones), turbo (may possibly be a chinese one as no Garrett stamp), and others. Will be posting on Craiglist so will provide a link to the posting.
Car runs great but got p0234 code. So checking for boost leak, N75 and MAF tomorrow. New Garrett turbo so that cannot be it.
2002 Jetta GLS - auto to manual, VR6 clutch, sprint 205s, panzer full metal jacket, DG short shifter
2002 Jetta GLS - stock for now
Stan TDI is offline   Reply With Quote
Old June 3rd, 2016, 19:44   #7511
[486]
TDI(s): 02 golf ALH
, block but likely bent rod as it hydrolocked, 10mm injection pump, injector lines (the hard ones),.
I might be interested, throw me a price by PM
Tons of 2dr black interior parts you can have free if you want them, oh and a stock base model radio/speakers
[486] is online now   Reply With Quote
Old June 4th, 2016, 19:59   #7512
gearheadgrrrl
Fuel Economy: Other than the JSW, hard as I try, can't seem tio get below 40 MPH!
2 door Golf interior? I've got an '03 with black dash and bluish grey seats, could use seats, etc. if your's aren't torn.
GearHeadGrrrl
gearheadgrrrl is offline   Reply With Quote
Old June 4th, 2016, 20:04   #7513
[486]
TDI(s): 02 golf ALH
The front seats are still in use, but the rear ones can be had for free
Old June 6th, 2016, 18:38   #7514
gearheadgrrrl
Thanks, I'm good for back seats (been folded down for years)...
GearHeadGrrrl
Old June 6th, 2016, 20:18   #7515
[486]
TDI(s): 02 golf ALH
If you pull them out there's a huge amount more room back there.
and the backs weigh like 60lbs together, enough that you can feel the extra pep
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.24375 seconds with 10 queries
[Output: 129.25 Kb. compressed to 107.84 Kb. by saving 21.41 Kb. (16.57%)]
