Mr.Staplehead
This is my first post so please be patient.... I own a 2011 Jetta Sportwagen TDI with 110,000 VERY HARD miles and my CEL came on... P0401 EGR valve stuck. Knowing that you can remove the EGR valve and the car will not become a time bomb, I cleared the CEL but it came back on immediately. I dont like to waste money but i do like exploring things i know nothing about. I took out the EGR valve and yes it was bad.... coated in burnt oil. (I will Post pictures when I figure out how)
I cleaned it and made sure everything worked properly. Reinstalled cleared the CEL and I was off to test drive. Nothing. 100 miles later nothing. 300 miles later. Nothing. 425 miles later. Pooh. CEL. Same code. OK. Ripped it back off.dirty again. Not as bad but still sticky burnt oil. WHYYYYYY!!!!! Time to figure out the reason. Researched it. TURBO SEALLSSSS!!!! AAHHH! Stripped down the intake to the Turbo. (Thanks Mike from M&M) OIL!? What?!!!?? Zero play on the turbo fan.Turbo's fine.
AAH the PCV! OK. So to the point of this post. I did browse a lot on this site and tried to find posts about my specific Motor (the 2.0 CR) doing a oil catch can adn I saw some but nothing exact. Can I do an oil catch can on this motor in my area? It definitely gets well below freezing in the mountains of northeast Pennsylvania where i live and there is an intake heater on that crank case tube. Sorry about the long winded story.
~Just a frustrated Newbie.
