kristian92
Hello guys!
I really need some professional help here.
April 2014 I bought my VW Golf MK6 1.6 TDI Bluemotion with the common rail system.
Shortly after that I felt that the starter was going for a longer time than it should do, so I went to the official dealer in Norway for a diagnostics. I had to do this two times without any results. They even had it for a week to start it every day to try to find the problem. Costed $185 for every diagnostics.
So, when I took it in for the first diagnostics I was told that the previous owner filled gasoline instead of diesel, and got a towing car to tow it to the workshop. They changed fuel filter and cleaned the tank.
I even recorded when starting the engine, but they're saying everything is Normal. This winter i had a problem starting it. Well, in -27 celcius (-16.6 farenheit) I might understand that it won't start without the DEFA system I've got installed. But in January when it was about -2.5 celcius (27.5 farenheit) it just died when I was trying to start it. It got to 1000rpm, then died. I changed diesel filter, but it didn't help. I had it for a diagnostics again, and they told me to change the diesel injector, which I did for $1228. But this didn't help either.
Sometimes it starts immediately, and the other times it takes 1-4 rounds more before starting.
Now I'm wondering about trying to change the glow plugs, just to do it and eliminate that as an option.
Anyone got any ideas? I really like my car and take care of it, but I need everything to run smooth too.
