Sbeghan
Hi folks,
My wifey needs a bigger car since we have a baby on the way and she wants a sportwagen tdi. I tried to convince her that the ALH Mk4 wagons are the way to go but that didn't go so well.
So here's the thing. We're on a budget, about 11k, but anything lower we can get the better. I've got VCDS and tools and am not afraid to use them, but I don't want to have to buy too many parts.
My understanding is the HPFP warranty is extended to 120 or 125k miles? Which is it?
I also heard that the DPF warranty was extended to 250k miles?
What are the warranties actually extended to?
I'm trying to judge relative worth of the cars we see for sale. I'm trying to price things based on keeping the car for 100,000 miles and 5-10 years.
How would you value the options, mileage, and conditions of the car given your knowledge and preferences?
*Moonroof: $300-600. KBB seems to put a $600 value on it. I think we'd like it and it would give the baby something to look at.
*Manual Trans: $500. KBB puts a $50 value on a manual trans. I would prefer the lower maintenance costs of a manual trans, though I hear if you do your own DSG fluid changes its affordable and pretty cheap.
*HPFP under warranty: $600. I think that will cover the cost of buying the add on 1um filter. I understand that the failures aren't that common, but its something I don't want to be caught with out of warranty. I can handle changing the HPFP itself but I don't want to have to replace everything.
Other than that, I don't know what other options we should be looking and and putting values on. Suggestions?
We've got a variety of cheap sportwagens that we see and are currently considering. The inventory turns over so if we miss them that's ok. Baby's not due till January.
Some examples:
119,000 miles. Manual. No problems. $10500
200,000 miles. Automatic. Some electrical bits and a cracked DPF. $8500.
Also, mechanically, what should I check before purchase?
I was thinking about checking the fuel filter for metal (I hear that's not very diagnostic though), and checking the appearance of the timing belt and the appearance of the cam and lifters (any cracking of the filters indicating a failed timing belt previously?).
Basically: $1000 of work on the car isn't a huge deal, but I don't want a time bomb that will cost more than $2000.
Some examples:
