pics - and a few notes on my install
The install is overall easy. A few of the difficult or slightly frustrating parts included:
1) Removing the small lower grills - I was worried about breaking things. After removal, I can see that the tabs on the outside of the small lower grills fit into a slot and are not meant to release easy. Start from the inside (medial) of the grill when removing them.
2) Removing the center lower grill - Same funny feeling that things will break when trying to pull this out. In my case, I was installing a replacement low center grill, as my old one was broken. The old one broke further as I removed it. No tips from me - I'll be nervous next time, too (suggestions from other??).
3) I think my kit, purchased from OEM+, was good and I liked the parts, including the harness; however, the trigger wire was a thicker gauge wire than any of the other wires that fed into the headlight switch via the clip. Fitting the trigger wire in required a little paring down of the insulation with a scalpel so the wire would fit into the clip. Also, I had to open the clip up to feed the trigger wire and it's terminal into the clip (use a small flat blade jewelers screwdriver to release the catch on the clip, then used same small jewelers screwdriver to help push the terminal all the way into the clip).
4) Any other difficulties were posted by me as questions earlier, but for a concise review:
~~ I guess I didn't need a highline module (whew)
~~ Idiot lights that lit up after reconnecting the battery went away after turning the steering wheel from limit to limit.
~~ and, most embarrassing to me: you need to PULL out on the Euroswitch to light up your fogs
The rest of the install followed the various guides/how-to's that have been posted. Thanks to those who have produced and posted them and to those who answered my silly questions when I needed help (tleader!).
