Macradiators.com
4th gear LOL
2nd is done in 2seconds max
All my tea just went all over my monitorOh no, wait, now I realise, time goes faster around where you guys hang out, like that 7sec 100-200 A5 video.
lol, so much work for that? WR...4th gear LOL
make your bets for the 100-200km/h acceleration
What u making here?
In english the metal lathe cutter is just called a "tool" or "tool bit" rather than 'chisel' and the one you use for inside bores is a "boring bar" which can do the cutting on its own, or alternatively be of the style that holds a carbide insert or HSS tool bitI didnt do for weight as I think more weight is better for less torque fluctuation on belt. jI sued alu just because I didnt have a good small bore chisel to make the cone in steel so alu cut much easier.
