ICTDI
Hi all, I just want to relay my 01M Transmission experience and story for your review and consideration.
In 2007, I purchased my 2002 Jetta used. On hot days, the transmission would slip badly. Upon acceleration, the engine RPMs would spin up and then the transmission would engage harshly.
I took it to VW and also the top-notch local trusted transmission shop, the owner whom I know personally. Both explained I need to replace the transmission. I saw the prices and pondered what to do.
I decided to do Triage... take a "no harm" peek at what I actually have going on.
I bought a clean see through sterlite container and dropped the transmission pan and let the fluid run into the container. Reviewed the inside of the pan, the magnet, and found what I would call basic micro particle wear... plus a few flakes stuck to the magnet. The fluid was hazy, darkened and not clear .
The transfluid smelled weird and was not the proper color. I had read about problems with VW fluids... and this transmission... whether accurate or not is not my call here, so, I contacted the Mobil 1 engineering folks on the telephone to see if they had a compatible formula. I actually spoke to a person who knew the chemistry, not a receptionist... They had just reformulated their Mobile 1 ATF, and even though it had not yet received a certification from VW, it exceeded their published standard. Secondly, there was not risk to combining the VW and the Mobil 1 formulas together. In essence, I would have to be sure the container label had the statement "Multi Vehicle Formula" on it. So, it just showed up at AutoZone and I bought a case and went home.
I know what you are thinking... as am I... why not take it in a do a power flush... blah blah blah, and you are correct! I am cheap.
I did a pan dump, and replaced the filter. I filled to proper level, it slipped, I added another .2 liters... and the car ran better. I drove it about 120 miles in hot weather, on the highway, then in stop and go traffic. I drove home and did another pan dump, and refill. It ran even better still.
The shifting issue went away. After another 10,000 miles, I did another pan drop fluid and filter replacement. Even better now.
So, over the past few years and 110,000+ miles, I have done 3 or 4 additional pan drop fluid replacements.
My Jetta has over 217K on it now and occasionally, I can't get it to go into reverse on the first try, and I have to shift to neutral or park then back to reverse to get it to grab, but otherwise, I have no transmission problems.
I don't want to muddy the topic, but I just was outside replacing my G68, when I thought I would post this story of my transmission history.
P.S. By the way, I tested my G68 with an ohm meter and it tested correctly. But after consistently getting the code immediately upon ignition on, I replaced it with another Output Speed Sensor, and the P0722 ODB2 code went away (I have to clear the stored codes with my OTC Genisys) and the car came out of limp mode... and runs great.
P.S.S. I got the P0722 and the P0228 codes at the same time. A rule of thumb I use is, replace the "no signal" code item before replacing the "intermittent", "hi", or "low" trouble codes items. I assume the latter types of trouble codes could be caused by the complete failure of the "no signal" part.
