Thinkdiff
Sorry for the long post. Long time lurker, but haven't posted much. I'm the 2nd owner of a 2002 Jetta TDI, bought at 127k - now at 169k.
Around 137-138k miles, the transmission started acting up - biggest issue was lagging when switching between 2nd and 3rd gear (the car would stop accelerating for a moment, then the gear would "clunk" in and everything was normal). Around 139k miles, I started experiencing the drop out of gear issues in park and at stand still. I'd have to rev up the engine on hills to get 1st gear to re-engage. It was also periodically throwing the P0740 (TCC) code.
I brought it to a local shop in Los Angeles to have it rebuilt. They swapped the TCC and rebuilt the rest of the transmission "as needed". Also filled it up with new fluid and checked it a few times in the first 5k miles. Not too long after, the 2nd to 3rd hesitation would occur infrequently, but overall it ran great.
Now at just under 169K miles, I cannot keep the transmission in 1st or reverse when going slow. The car also "shudders" when going very slow (under 2-3 mph), making for an always interesting event pulling into my small garage. Trying to get from 1st gear to 2nd gear at a reasonable speed results in huge over-revving followed by a "clunk". I can get a relatively smooth shift if I basically stop accelerating around 20MPH and just wait for it to drop into the next gear. 2nd to 3rd also has it's lag/clunk problem unless I stop accelerating around 45MPH.
From talking to a mechanic (he didn't inspect it yet, just listening to the problems), it sounds like at least the valve body is done, if not more damage due to that problem. He recommended a reman as the only "reliable" fix, excluding a manual swap.
So my options seem to be:
1) trying another diagnose/partial rebuild (at least fluid flush + valve body) - $2-3k?
2) reman transmission - quoted around $5k installed
3) lease/finance 2013 TDI - $2-3K down + trade-in value + monthly payment
For option 3, does anybody have an idea of what I may get either trade-in or private sale with this transmission problem? There's not a lot of used TDIs in the area to compare at the moment (San Jose, CA). Besides the transmission, the car is in relatively great shape. Few dings/scratches, recently replaced tires/front brakes/rear struts + regular maintenance.
What's the general consensus these days on how to handle the 01M? Is the mechanics assessment reasonable given the symptoms and fact that it was already rebuilt once? I'm not getting any CEL codes, but haven't used VCDS yet to pull the codes on the transmission itself.
Manual transmission is pretty much out of the question (never driven one and I usually drive in traffic - can't imagine it would be pleasant). I can make some repairs on the car myself, but I'm definitely not ready or setup for transmission work.
Thanks for reading.
Thanks for reading.
