Timing oscillation on my 1.9 TDi AHF
Hi, I'm new to this forum user. I write from Spain.
I know this forum you have much knowledge about the TDI and I would like to consult you on the swing timing on my car with 220,000 kmts.
When I connect the PC vag com to see the timing is not fixed to one number, the value ranges between 46 and 52. The car runs perfectly and always turn quickly.
You know if this oscillation is normal or should I worry? The next change the timing belt is the 260,000 kmts. You think it should forward the change?
Crankshaft Gear is that it wears on these engines and produces oscillation in the timing and when you change the timing belt going to put a new one.
You think that the swing 46 to 52 need to change it now?
Thank you very much for your attention.
Greetings.
Greetings.
