B5.5 Passat TDI AC problem
apeto
Argentina
2005 - 1.9 TDI - AVF
Hi all, I have a problem with mi climatronic A/C. When the car is at low rpm, the A/C works ok, I can feel some cold from the vents, but when the car is running, like highways, etc I dont feel cold.
I measure the psi, when the car is idle, i get in the high port 200 increasing till 350, then stops. In the low port I have around 40 lbs.
When the car is at 2000 rpm, the high decrease till 140 lbs and the low is always at 40 approx.
Is it due to expansion valve? does this cars has expansion valve? is the compressor bad?
Thanks for all your help!
