BigTurboAlh
Looking to convert over to solid lifters. I seen a post about 1.7 diesel Nissan lifters but what lash caps
Well last 2 years I built this engine I’d do a pull to 5500 rpms and let off it would start ticking and missing. You can hear it out the exhaust then it goes away. I was told to put black coated lifters in it and now it still does it. Idk what else it could be. I have a oil pressure gauge in it and it’s perfect. So now I’m after a solid lifter set up.
How much boost are they running? I see 48 on a small tune 62 on a big tune. Mine did this with a single charger and a hole different head. I guess I’ll put a drive gauge on it. That hx30 is plumbed into the hx40s outlet. If I plumb the 30 into the manifold it won’t light the 40.
There is no external waste gate. The hx30 is 6cm has a internal waste gate that I ported to just under 1inch. It opens gate at 20psi It goes out the hx30 into the 21cm hx40. I’ve only did 2 pulls to 62
I'm running 0w40 in mine with the small gear, hopefully it's enough, if not it might need a bigger pickup screen and pipe@486 it does have a small pump gear on it. That’s probly what’s happening.
I can't recall just how loose I run the exhaust valve guide to stem clearance only that they are likely at the maximum limit for the OE tolerance.@andy2 Engine is up to operating temp every time. I have dual valve springs. But might get tt springs here soon.thats the first I’ve heard about the exhaust guide and egts how loose you run them. The hx40 has a hx35 wheel with 21cm housing. I had a 18.5cm on it but I liked the 21cm better cooler egts. I thought the 1.5/1.6 lifters was too small for the alh head?
there is a special depressor tool that lets you remove the shim without removing the camolder vw 1.6D and even older 1.5D motors also had solid lifters available
pain in the ass, gotta take the cam out to adjust lash
