Old June 16th, 2019, 12:21   #1
GlowBugTDI
GlowBugTDI's Avatar
Fuel Economy: 43 mpg average
Default MAF or n75 valve??
Hi all,
the other day I lost boost in my beetle, this is the second time it has done this in a month. that actuator is fine. i fiddled with the n75 valve and i can blow and vacuum air both ways through the black spout on the lower right side. is that normal? somewhere i had read that means it's bad or something... either way i couldn't get boost back. so i tried unplugging the maf. i drove it out the driveway and boost it works!! drove it half a mile, plugged the maf back in, and now it drives great. is my maf going out? a bad connection? this is the second time it has happened to me (both in the past month). last time I turned the car off, restarted and it was fine. Did that a couple different times actually, but it had been fine for the last two weeks until yesterday.
Thanks,
GlowBugTDI
GlowBugTDI is offline   Reply With Quote
Old June 16th, 2019, 12:23   #2
csstevej
Any CEL ?
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old June 16th, 2019, 19:38   #3
GlowBugTDI
GlowBugTDI's Avatar
check engine comes on but i also had to do an egr delete (kinda broke off and shot exhaust out by the windshield wipers), so that comes up as well. when there wasn't any boost though the light wouldn't be on then soon as the ecu shut the turbo down the light would come on. where as normally the engine light is always on because of the missing egr.
mk3 n75 valve pn I need a n75 waste gate vavle pn 028 906 283F clearprop75r Private TDI Items for Sale/Wanted 0 September 13th, 2014 13:54
n75 valve and n18 valve for sale TDIPWR33 Private TDI Items for Sale/Wanted 7 April 7th, 2014 13:24
AHU N75 Valve for sale, and 627 A N18 Valve TDIPWR33 Private TDI Items for Sale/Wanted 3 December 12th, 2013 17:35
wtb: 99 n75 valve and a 00-03 n75 valve bekir Private TDI Items for Sale/Wanted 2 May 7th, 2012 20:14
FS: BNIB N75 valve (turbo actuator control valve) Jesse_Boyer Private TDI Items for Sale/Wanted 4 October 8th, 2007 05:27
Page generated in 0.11613 seconds with 13 queries
[Output: 58.73 Kb. compressed to 53.41 Kb. by saving 5.32 Kb. (9.06%)]
