Old April 21st, 2016, 14:55   #16
Carlos_TJ
When i first got my tdi, the fan squeaked and only worked in high.
I replaced the resistor pack with a junkyard part.
I blew the motor with compressed air and soaked it with wd40 (i do this every year when i replace the cabin filter)
Carlos_TJ is offline   Reply With Quote
Old April 22nd, 2016, 13:37   #17
jay.sejkora2011
jay.sejkora2011's Avatar
My blower also sqeeks a bit. I might try this once I get around to fixing this no-AC problem.. Geeze it's getting hot out here. Been without AC for maybe two years.. Enough is enough.
jay.sejkora2011 is offline   Reply With Quote
Old June 16th, 2019, 16:56   #18
dx1001
TDI(s): 2003 jetta
Fuel Economy: low 40's
Hello _my 03 jetta tri blower only working on 4 and the ac will not engage when fan runs. I could live with high speed for now but not without a.c... Is this normal??? Just a bad fan/thermal fuse? Thanks!
dx1001 is offline   Reply With Quote
Old June 20th, 2019, 08:41   #19
Nuje
Sounds like a blown resistor pack to me, dx1001.
But like mentioned above, the resistor blew for a reason (too much draw - most likely from the fan), so I'd be looking to replace both.
His ride: 2015 GSW SEL TDI with MIB2, Active Info Display, Adaptive Cruise retrofit
Her ride: 2016 A3 e-tron
His other ride: 2015 Giant Propel SL Di2
Nuje is offline   Reply With Quote
Blower works on High only Boatman VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 19 September 2nd, 2011 05:29
Climatic blower only works on high setting jimwin TDI 101 21 October 13th, 2010 18:31
lost blower speeds 1,2,3 but 4 still works metalgouger TDI 101 19 June 19th, 2009 06:43
Blower fan works only on High! DeGolf VW MKIV-A4 TDIs (VE and PD) 4 May 8th, 2008 22:11
Page generated in 0.08139 seconds with 13 queries
[Output: 63.58 Kb. compressed to 57.06 Kb. by saving 6.52 Kb. (10.26%)]
