neb32
My 12 JSW had front-end damage, I want to swap to the GTI front end. I am looking at replacing the bumper cover and headlights to some used ones I have found from a GTI.
My questions are the OEM HID headlights, will they work with my OEM plug or do I need a different wiring harness? I have a vagcom so programming shouldn't be too difficult. Do I need anything else?
I wired in the fog for the standard Golf, are the fogs for the GTI a different plug?
Lastly, the GTI has headlight washers. What do I need to make this function?
Thank you in advance!
