Old June 9th, 2018, 22:39   #1
surfstar
Question 2011 Golf No Start - help please!
Got a bit of a project:
https://www.youtube.com/watch?v=BkQn0SVbti4
This car sat for an unknown amount of time (up to a year+ possibly?), then I got it a few months back. Couldn't work on it until recently, and I knew the battery was going out and causing a no crank issue then. Only info I had. I pulled codes (only have OBD11 not VCDS) and got
P2463 - Diesel Particulate Filter - Soot Accumulation static
P2016 - Intake Manifold Runner Position Sensor/Switch Circuit Low static
Then it sat for a few months and the battery fully died.
Finally got time to grab a new battery today to throw it in. I was hoping it could be the fix, as these cars seem picky about proper voltage according to my research.
Car sat long enough with a dead battery that doors wouldn't lock, etc, and codes cleared I believe.
Cranks now, still no start. See video of attempts, if it helps.
Pulled codes: same P2463 and P2016.
Cleared codes, then did only one start attempt and the codes didn't set. Fuel issue?
I've been researching what I can and don't have much experience with TDIs. Anti-Shudder Valve (ASV) - can't find it. On a CJAA I think its integrated into the intake manifold, correct? Can it still cause a no-start? P2016 related?
Fuses seem fine.
Afterwards, I checked the fuel filter and didn't see signs of metal debris (2011 w/ 146k mi, unknown service history). Will priming possibly solve the no start? Didn't crank after cracking open the fuel filter. I need to manually prime without VCDS, unless I can find a way with OBD11.
Apparently a flashing glow plug light doesn't mean that they are bad.
Other avenues to explore?
Any and all help appreciated!
surfstar is offline   Reply With Quote
Old June 21st, 2018, 21:00   #2
surfstar
Bump for any thoughts...
Old July 11th, 2018, 19:49   #3
surfstar
Primed the fuel system with OBD11, tried again, cranks - no start still.
Tempted to try starter fluid!
I've read the debates on that, though...
Old October 1st, 2018, 20:05   #4
surfstar
So, I couldn't get it to fire on WD40 - but a bit of stater fluid and it did fire.
I disconnected the glow plugs first.
Wouldn't stay running, but it might have been enough to get me a new code:
P0087 - Fuel Rail/System Pressure - Too Low Short circuit to B+
static
now to read up on FP issues... and hope its not the HPFP
Old October 1st, 2018, 21:16   #5
turbobrick240
turbobrick240's Avatar
Sounds like it might be an immobilizer(ecu) issue. I'd leave the ether alone and prime again with the fuel line from the filter disconnected and routed into a container. Maybe one of the electric pumps crapped out.
Old October 2nd, 2018, 21:39   #6
surfstar
yeah, looks like HPFP
Pulled the fuel metering valve and found glittery bits all over the mesh. Looks like its time to investigate the cheapest way to limp around the dealer lot with a replacement / fuel cleaning / etc ...
d'oh
Old December 5th, 2018, 21:57   #7
surfstar
Ended up putting in a reman bosch pump from RockAuto and also having the shop clean/flush fuel lines - no other pump replacements or injectors. Ran rough. I never started it until the buyback appt - towed to street outside dealer. Drove in. Drove backward/forward 5' for the buyback. Got my check. Labor and parts were about $1300.
AAA towing to multiple locations - a deal!
2011 Golf Wagon - Start then stall The_Hamster VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 November 1st, 2015 07:01
2011 Golf 6spd Start Issue llancaster12 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 June 14th, 2015 18:44
2011 Golf No Start Mystery Cogen Man VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 November 17th, 2013 17:05
TDI golf SW 2011 won't start at all bosa VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 2 April 16th, 2013 16:28
My 2011 Golf vs 2011 BMW 530d rental c17chief VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 December 15th, 2011 10:12
Page generated in 0.14392 seconds with 11 queries
[Output: 78.71 Kb. compressed to 68.46 Kb. by saving 10.26 Kb. (13.03%)]
