I just finished a timing belt change recently where I noticed when putting the serpentine belt back on that the lower T.B. cover sticks out a little past the inner lip of the harmonic balancer. The serpentine belt will go on fine, but the cover touches the inner side of the belt. The cover seems to be flexible enough that I can push it back and everything will clear fine.
I thought maybe this problem would have been caused by the 3rd lower cover bolt missing. That one that's a T-head bolt that supposedly always falls out was never there since I purchased the car last year. I've never noticed this issue before, never got any strange sounds, and the old serpentine belt appears to be fine (i.e. no signs of rubbing).
I ordered in that bolt and put it where it belongs, but the lower part is still rubbing the harmonic balancer. It almost feels like the harmonic balancer is too close to the block for some reason. Either that, or the lower T.B. cover is sticking out too far or is bent. I have no reason to believe the lower cover got bent, but I'm not ruling it out.
Any ideas?
Any ideas?
