Old April 21st, 2010, 11:00   #1
BumbleBeeTJ
Default vcds mods
**not responsible if you screw up. do it at your own risk**
already done the following
-lock confirmation honk disabled
-convenience opening/closing windows
-coming home
-now the start "ding" sound is different(watch vid) dunno why or how it happened
-seat belt chime gone
-DRL disabled
open VCDS and go to Select Control Module
go to 09-Central Electronics
click on coding
click on long coding helper
PRESS PAGE UP/DOWN to see all the menues and you will see options for the auto lock, honk disable, coming home, leaving home, footwell lighting(lights up with light on @ 20% or higher brightness) and others... some options show up AFTER you have enabled the feature or disable the feature.
go to 17-instruments, follow above steps and you will see brake pad sensor and seatbelt chime options
go to 4F-Cent. Elec II, follow above steps and you will see tilt/slide option for comfort open/close as well as sunshade open/close option
thats it for now
2010 CandyWhite JSW TDI DSG w/Pano
VCDS mods for now
BumbleBeeTJ is offline   Reply With Quote
Old April 21st, 2010, 21:24   #2
biby
TDI(s): MK6 Golf
The sound in your video is indeed the other option for seatbelt chime.
If you want to disable it you need to do it in the long coding of cluster.
biby is offline   Reply With Quote
Old April 21st, 2010, 21:37   #3
BumbleBeeTJ
yea I realized afterwards and disabled the "chime" when turned to ON position.
But i liked the "different" chime so i left it back as you see in the vid
also did Sunroof slide with remote open it only tilted before
adjustment for the footwell lighting enabled when headlights are on
cominghome/leaving home feature enabled(need euro switch for leaving home)
VCDS mods for now
Old April 22nd, 2010, 08:14   #4
dpg
i think once you disable the seat belt chime, it changes the chime once you start the car. thats what i noticed in mine
dpg is offline   Reply With Quote
Old April 22nd, 2010, 10:37   #5
Pelican18TQA4
VAG-COM has had an option for the MkV cars to open the sunroof with the remote for years now but it never works. Seems that's not the case on the '10 JSW!
Leaving Home should work with or without a European switch, or at least that's the case with the MkV cars. Without the rain/light sensor however, the lights will come on every time you unlock the car, not just when it's dark out.
"I interviewed the late Steve Yokich, then UAW president, almost ten years ago. When I suggested that Detriot might be putting too many eggs in one basket with its utter devotion to SUVs at the expense of passenger car development and asked if the union might take a position in favor of more economical cars, he started screaming at me." -Jamie Kitman, Automobile
Pelican18TQA4 is offline   Reply With Quote
Old April 22nd, 2010, 15:21   #6
BumbleBeeTJ
tried leaving home but without euro switch i don't think it's possible.
also did tear drop disable for the rear wiper. i thought i was going crazy seeing the wiper go off after i've turned it off! lol
now what else can I do? I'm pretty much done lol
edit: apparently my seat belt chime is indeed gone but start up ding still remains? either way im okay
VCDS mods for now
Old April 23rd, 2010, 21:03   #7
MuthaFunk
MuthaFunk's Avatar
Fuel Economy: 5.8 L/100Km
I like to vote this thread to be added to the sticky's!! We just need a little detail on how some of these are done on the Vag Com. For example, I have the remote windows set up on mine but my sunroof doesn't scroll all the way back. Only tilt. I didn't see anything that was obvious in the Vag Com to enable that feature.
MuthaFunk is offline   Reply With Quote
Old April 26th, 2010, 05:11   #8
MKV TDI
TDI(s): 2010 Jetta
can you post the codes for these mods please? I have a 2010 Sedan and the codes I have found are for the MKV's and I know my car is a MKV but the coding isnt working. I think I need the coding for the MKVI's. The coding was rejected for what I had found for the seatbelt chime and the windows with key fob and I am having issues getting the phone in the MFD properly. The only code I have done successfully is DRL.
MKV TDI is offline   Reply With Quote
Old April 26th, 2010, 08:19   #9
BumbleBeeTJ
give me some time and I'll try to post step by step on the HOW TO
then they can sticky that and delete this thread
VCDS mods for now
Old April 26th, 2010, 22:25   #10
nj1266
TDI(s): Golf
One thing that I found very annoying and had someone with a Vagcom cable remove, is the auto lock once you drive above 9 mph.
nj1266 is offline   Reply With Quote
Old April 28th, 2010, 05:00   #11
MKV TDI
TDI(s): 2010 Jetta
but the autolock keeps strangers from entering your vehicle while it is in motion.....
Old April 29th, 2010, 11:37   #12
Parva
Parva's Avatar
Gotta admit to being a bit of a chicken when it comes to me altering electronics in such a modern car.
Otherwise, I'd put in an order with RossTech & do these things myself.
I really want to do all sorts of alterations that can only be done via Vag-Com.
So, with that in mind, I'm trying to find someone in South Florida that has experience with a '10 JSW Tdi... Anyone?
Parva is offline   Reply With Quote
Old May 1st, 2010, 14:03   #13
gnatman1102
Right after the engine starts on my Golf, I get a single "ding" on random occasions. don't know what it is for. The door is shut and my seat belt is fastened. I have the VAGCOM, but I cannot turn it off.
Any ideas?
It is more of a nuisance.
gnatman1102 is offline   Reply With Quote
Old May 1st, 2010, 14:30   #14
rabinabo
Do you connect to bluetooth with your phone? Could be that.
__________________________________________________ ____________
2010 VW Golf TDI - Black 4-door manual w/ sunroof, Dynaudio, cold weather package
Major changes: 9W2 -> 9W3 bluetooth, RCD-510 -> RNS-510 (soon!)
Have Micro-CAN, PM for help if local
rabinabo is offline   Reply With Quote
Old May 1st, 2010, 18:08   #15
HeAvYfUeL
HeAvYfUeL's Avatar
Fuel Economy: Fuelly signature --->
For the people who are interested I think the A6 cluster can do dial staging (sweeping dials at start up). according to this thread.
http://forums.vwvortex.com/zerothread?id=4802735
2009 Jetta Wagon Comfortline DSG ESP build 03/09 Graphite Blue
History:
2006 Golf TDI GLS/1992 Jetta 2.slow GL
HeAvYfUeL is offline   Reply With Quote
Page generated in 0.18400 seconds with 10 queries
[Output: 124.48 Kb. compressed to 103.31 Kb. by saving 21.18 Kb. (17.01%)]
