jmann8686
So after a long couple of days doing a bsm delete on my 05 passat. I was able to fire her up for the first time. It has all new belts new water pump new tensioner pulley and idler roller. Got my kit from bora part. So I turned the key and it started right up with out a problem. Got out of the car and looked around the motor to make sure there was no leaks or anything out of place. It is running fine. No CEL. And it revs up good. But there is an odd noise coming from around the pulleys. You can't hear it anywhere other then right next to the camshaft and alt pulley. But the noise goes away when you rev up the motor. Just wondering if that is just new parts breaking in or is something wrong. Hope the video works. http://youtu.be/d9xCLa7hVVQ[/URL
