I think 1/4" is overkill for the portion of the bracket that sits next to the block. Now the parts that extend out to the framerails may need to be beefier depending on what your brackets end up looking like. Anything mocked up that you can share?And finally I got my templates made for my motor mounts and started to cut them out but after cutting the first of 6 pieces I kinda started wondering if 1/4" metal was too thick. It certainly seems to be.
Would 1/8" metal be alright? I'd hate to go with the thinner stuff only to have it fail. What say ye?
Well right now my "mounts" are 6 pieces of beer box cardboard. I'll post some pics of the pieces tomorrow. I meant to do it this evening but got sidetracked...the wife wanted to eat. Really, who eats when you're making progress in the shop? I tell ya, some people.I think 1/4" is overkill for the portion of the bracket that sits next to the block. Now the parts that extend out to the framerails may need to be beefier depending on what your brackets end up looking like. Anything mocked up that you can share?
Haha. Yeah, you needed more template materialWell right now my "mounts" are 6 pieces of beer box cardboard. I'll post some pics of the pieces tomorrow. I meant to do it this evening but got sidetracked...
I don't think the wife believed me when I told her earlier today that I had to run to the store to pick up a 12 pack of shiner bock for the template material. Maybe tomorrow I'll need some guiness templates.Haha. Yeah, you needed more template material
Like an idiot I used old Cheerios boxes! Should have though ahead on that one.
Most swappers replace the "porcupine thingy" with the one from the automatic transmission equipped ALH VWs (pictured below; pictures borrowed from greengeeker's Ranger build thread http://forums.tdiclub.com/showthread.php?t=359848&page=2) as it cleans up coolant line routing and saves space by not having the coolant line run straight at the firewall. greengeeker also chopped the metal tube that runs across the back of the head down to make it work better with his transmission bell housing (also pictured below; from the same thread as before). As for the small pipe that comes off the back of the head, I believe it teed into the line that ran back to the overflow tank, so I don't know what effect running it into the return line to the water pump (the metal pipe that you want to tee this line into) will have. I say run it to the overflow tank instead of tee'ing it and that keeps with the coolant flow path that VW designed for this engine.Well I got some work done today. I plan on picking up where I left off tomorrow. I got my turbo clocked up and out of the way which was a heck of a lot easier than I thought it would be. Which is always a pleasant surprise. I then decided to whittle down my cooling system to match the diagram I've posted earlier in this thread. You can see the difference in the before and after pictures. It may not be obvious but it really cleaned up a lot. In the pic with the 3 glowplugs (porcupine thingy) in fitting on the back of the head, I'm wondering if I can just put that little line and larger line together and then just attach them to the metal line going into the water pump. And finally I got my templates made for my motor mounts and started to cut them out but after cutting the first of 6 pieces I kinda started wondering if 1/4" metal was too thick. It certainly seems to be.
The duct taped hoses ^^ if I tee those together and run them straight into the metal tube, will that be alright?
Well I don't have a scanner but if anyone really wants the templates for my ghetto mounts I can write the measurements on them so they can replicate them from the pics. Really there are only 2 pieces out of the six that have anything other than straight angles. With enough determination they could be replicated easily with a cutoff wheel and flap disks. Which is damn near all I used.If you have a scanner - throw the templates on and scan them 1:1.
I spent this morning down in the garage working on my mounts. Same template material. Seems like after the baby, there's a lot more cheerios boxes than beer boxes.
I went with nuts as spacer mock up so that I could be sure everything would work and clear. I'm glad I did because it turned out the bottom bolt was hitting the belt. So I went with a smaller spacer and put a single washer between the pulley and the bracket and it came out perfect. It slides easily enough. I did have to use a pry-bar to push down on it to tension the belt enough but that's just because I'm not the strongest dude. Over all, I'm extremely happy with it thus far. The belt came from Oreilly Auto Parts, part # K060551.did you make your bracket any thicker in the middle there where you mounted the pulley?
It is flat strap that I put spacers behind. The spacers are currently nuts that were the right thickness. I've got some small diameter tube I'll replace the nuts with but I wanted to be sure I got the distances right.
how thick is the material you used? 1/4"? 3/16"? did you need to tack on a nut to screw the idler into?
The material is 1/4" x 1.25". Not sure where I got it, it's been over in my scrap pile for a while. I did not tack the nut for the pulley bolt. I may come back and do that but for the time it's just got a nut on it. There is a washer between the pulley and strap.
can we get a profile shot with the pulley unmounted? and does it slide up & down easy enough with your one slot angled differently compared to the other?
Believe it or not, that top slot is angled on purpose. I did that so that as it slides up it moves away from the timing belt cover. I should have angle it more but hindsight and all that.
sure happy to see this option getting more use. its seems like a very simple, elegant solution for removing the AC compressor.
Thanks for that. I'm always a little nervous to post up pics. I know my skills are nowhere near what others have done.Nice work!
I know the fab skills aren't up to par for some of the stuff I've seen on here but it's all tightly fit and welded strong. So ugly it may be but it'll hold.
I had debated a rear mount radiator but the Willys tubs are so tiny that I don't really want to give up the space. Plus I could see some tard coming along in a parking lot and burning his hand on it because he went poking where he didn't belong. And I've already got to put the fuel tank back there. Space is extremely limited in these, more so than my 68 Beetle. The rad would still be in the engine compartment so even a hard roll wouldn't hit it. Crap being thrown up by the tires would be my biggest concern. Mounting in the hood really isn't an option either since the motor is so tall I dont have the vertical space for it and it's not a sealed system. Gotta love trying to shove ten lbs of crap in a 5 lb bag.A lot of competition rigs that I have seen run the radiators behind the cab area to protect them. A down side I can see with a side mount is a side flop or hard rub against a boulder on that side could damage it. Maybe, instead of mounting it on the side, either mount it behind you or an adaptation of the way the Hummer H1 has the radiator mounted, above the engine and nearly horizontal.
