tjl
How effective is sucking out oil through the dipstick tube, compared to draining it from the bottom, when doing an oil change? Since the TDI oil filter is changeable from the top, sucking the oil out can avoid the need to use ramps or remove the bottom engine cover.
If it is effective, would a hand pump like the Jabsco Handy Boy (about $36) be reasonable, or would the automatic suction version like the one at Griot's Garage ($65) be a better choice?
