After a broken timing belt, I swapped the head on my ALH and did the full timing belt kit. The head that I removed had two dowel pins. I replaced with a rebuilt head, and installed with both dowel pins. After install, engine starts and runs, code for intermittent miss on #1. I also have a serious oil leak between the block and the head. Is it possible that the head I replaced the original with wasn't milled to accept both dowels and didn't seat properly? I can't think of any other reason it wouldn't seal. I've heard some ALH heads only take 1. Compression on the gauge checks low (though I didn't get good readings on any of them, 2-4 shows 200 or so on my gauge, 1 shows maybe 50). Head gasket installed facing up with tab and holes behind IP.
Anybody have any ideas?
