Flashing Glow plug light HPFP
zmann96
New Hampshire
2012 Black Passat TDI Premium SEL
I just started getting the flashing glow plug light , reader says it's the HPFP. I've been searching all over for a rebuild kit for the Bosch 03L130755AA pump. Does anyone know where I can get a kit to rebuild. I have 120K for mileage so that extended warranty isn't going to help me. Has anyone done the repair or just replaced the pump. Thanks
Springfield, VA
Does the engine still run? If so, just park it until you can sell it back.
If you really want to keep it, there are options out there for upgrading the pump. Check with AARodriquez at http://www.fixmyvw.com
jetlagmech
Toledo, WA
2010 jetta
If the HPFP sent out metal shavings then its more than just the HPFP. Injectors could have metal in them. metal in the fuel tank, lift pump. flushing out or replacing the fuel lines so old metal doesn't ruin your new HPFP Its usually more work than just replacing the HPFP.
JSWTDI09
Las Vegas, Nevada
There are actually several ways in which an HPFP can fail. Unfortunately Jetlagmech has described the most common failure where the entire fuel system is trashed. It can, however, fail in other ways that are not nearly as disastrous. Knowing the exact fault codes that your car has stored would give us more information.
Also you can remove the fuel metering valve from the top of the HPFP and look at the intake screen. If it is full of metal shavings, you are in trouble - your HPFP has self-destructed. If it is clean, it could be other problems. As a general rule, I would try to find a TDI expert and try to avoid dealership service departments.
Have Fun!
Don
turbobrick240
maine
Forget about a rebuild kit. The CP4 pumps are basically disposable. If you really want to keep the car for the long haul, the cp3 pump kit is nearly indestructable.
tvmaster
Socal
2010 JSW
We had this happen yesterday: loss of power, chug chug, glow plug warning light, and then, three minutes after the light appeared (first time in the cars history, btw), we could not restart the car.
Towed to our home-dealer, awaiting assessment. Any suggestions?
What, if any, parts of a 2010 JSW TDI had their warranty extended? I thought I read somewhere here the HPFP had been extended, but since no fix has been announced yet, we haven't decided on buy-back or fix.
I'd sure hate a $5k bill from VW, to be sure....
tdiatlast
Fort Worth, Texas
My 09 JSW HPFP VWoA warranty is extended to 120k miles. Don't know about 2010s.
Probably best to post in the MKV area...
jrm
Oregon
2013 Passat SE with nav (totaled)
this would be the second known HPFP failure, did you fill up at a new station?
jetlagmech
Toledo, WA
2010 jetta
I got the letter years ago for my 2010. HPFP warranty extended to 120,000 miles. but have been seeing posts here about some VW dealers reverting back to their old ways of blaming the customer......claiming bad fuel thus not covered. or saying if you didn't get the misfuel device installed by recall (that some found was an anti any fuel device) then not covered.
shawn120
Vancouver, BC
2004 Jetta tdi /2010 Golf TDI wagon-Candy white -Pano/multimedia/DSG
2010 HPFP failure
You should be good if you are under 120,000 miles.
The US has the extended warranty.
Mine just went on my 2010 last week....I am fighting VW Canada, as we did not receive the warranty extension up here
