BakoTDI
Thanks!!! This helps!Here’s 2 wiring diagrams, slight difference depending on if you have power windows or not.
Stock wheels, 195/65 R15 Yokohama's and when speedo says 70, GPS on phone and dash cam reports 65/66? Is this normal for VWs?That tire size is going to lower the rotations per mile, throwing off the odometer and speedometer. If your speedometer shows 70 mph, you'll be doing an actual 70 mph. So beware of speeding tickets!
And you might think your fuel mileage has dropped when it actually hasn't. The odometer just doesn't reflect you've actually driven more miles than it shows.
Never run into it before, as long as I was running the 'factory' tire size. 97 Dodge truck, 96 Saturn GL2, 2000 Toyota van, 2013 RAV4, speedo and GPS match +/- 1MPHI believe many auto makers falsify the speed reading to display a higher speed in the top gear. Mazda did the same with my 1990 Miata with the OEM 14" wheels and tires but set it to read 5mph higher. So when I was driving the speed limit at 70 mph indicated, I was really going 65 mph true.
That's an interesting statement; if you dont mind sharing the source for it. Has me curious simply because I know for a fact that if the vehicle was off by more than 5km/h in either direction they wouldnt give you the annual TÜV approval in my home region. So if this was to be true would make sense in a way for sure!German law prohibits speedometer readings that are the same or lower than actual speed. So most cars read a bit higher. My BMW reads 4 MPH high, but my old Mercedes is almost exactly correct. Early TDIs (Passat and Jetta) read about 4 MPH high, maybe a bit more. I have slightly larger diameter tires on my B4 to minimize that error.
Ask a local leo to do a courtesy test. If they are a half way decent person they would help you with it. Or check a dyno maybe? In Germany they had rollers at a lot of local shops to check this when I was still there at leastI've found my oversize 215/55/16s, diameter of 25.3" vs stock size at 24.9"
is just a hair high on the speedo at 70mph referenced by GPS. I believe
it's thrown the odometer out though by a ~1.6% percent. I don't worry
about that, I want to know what the radar guns are picking up.
Something curious I noticed on my car related to the Speedo and odometer. My Speedo is like most a little higher than the actual speed as verified by GPS. The interesting thing is that when I plug in an obd 2 reader and read the value the computer is using for speed, it is almost dead on the same as the GPS, even though the Speedo shows higher.
Not sure if that applies to other cars, but food for thought for those changing their impulse settings with stock wheel and tire sizes. By getting your Speedo to display "correct" you may actually be causing the odometer to read incorrect (if the computer is using a lower speed value to calculate distance, etc.)
Sent from my Pixel 3 XL using Tapatalk
Finally got around to doing the 5 brake light mod on the '01! Wife was not impressed. smh
Passed the CA Smog Test today. The guy did a hard visual inspection but all the emissions equipment is intact, so nothing to worry about. Passed the Snap Throttle Test with no visible smoke.
FYI, I recently failed the Snap Throttle test at a different smog shop. The guy was rev’ing the motor and causing slight puffs of diesel smoke. After recently changing the fuel filter with a diesel purge priming and driving aggressively for a tank, the wagon is cleared for the Snap Throttle test, at a different smog shop. This guy said diesels have some leeway on the Snap Test and the fail is supposed to occur if smoke lingers for three seconds. That was not the case with the initial test and fail. No way did the wagon have lingering smoke for three seconds. Anyways, glad it passed with no smoke at all during the Snap Throttle Test.
The Snap Throttle Test is a SUBJECTIVE test not an objective test. The tester can make his own decision if it passes or not. It is best to do it outside on a breezy day.Passed the CA Smog Test today. The guy did a hard visual inspection but all the emissions equipment is intact, so nothing to worry about. Passed the Snap Throttle Test with no visible smoke.
Here are the test requirements for a Fail:
- Diesel - a visible smoke plume observed 5 to 15 feet from the tailpipe(s) that lingers for more than 3 seconds on either of the final two BAR Snap Tests.
