2nsane
Car- 2013 Passat TDI SEL
Miles- 45,000
Trans- DSG
MODS- N/A all stock.
Issue-
44,000 miles we noticed that our E-Brake was hard to pull up and took it to dealer they said everything was working as designed and that the automatic adjusted had taken up slack in the brake cables. Said not to worry its normal.
45,000 miles after getting home from 20-30 mile drive got back home and after getting out noticed a STRONG brake/clutch smell coming from car, its an auto so clutch smell is ruled out, walked around car and got stronger at back of car, bent down and immediately felt heat coming from back right back brake, looked and rotor was black in color, went to left side this rotor was all sorts of pretty colors and tinking as it was cooling down. walked to front of car and almost no heat at all. double checked ebrake was not enguaged and nothing it was fully down. took to dealer and they could not find an exact cause to the problem, they are currently replacing both calipers/pads and turning rotors, they said that the calipers were releasing slowly. I can see one or the other but both to have issues? hmmm sounds like something else. I think it has something to do with the cable adjuster automatically taking up too much slack and is putting pressure on the rotors which dealer said cannot happen. OK they are the pro's, so I will take their word for it. So far this particular dealer has been extremely helpful with everything and extended warranty is covering it all with exception of $100 deduct.
So has anyone had this issue with their B7's? and if so what was the root cause of the problem.
Miles- 45,000
Trans- DSG
Issue-
