Old February 19th, 2012, 09:05   #1
oil_me
oil_me's Avatar
Fuel Economy: 51,38,43
Default '91 Audi 80 quattro M-TDI
It's time to get my project on the pages. A BN VW TDI long block(AHU) came up for sale in '08. I scarfed it up being a diesel only guy with the intent of putting it in some kind of undetermined project.
I've been swapping drivetrains in and out of VW's for 35+ years; the bodies get rusted out or crashed and then it's find another good body & repeat. I've had been exclusive to VW's all this time save for 2 Chevy trucks ; a '58 Apache and a '71 plow truck, had over 20 beetles, 4 squarebacks, fastback, 1 '65 kombi, 3 german rabbits, loved my diesel vanagon, with my favorite cars being the 4 Dashers.
I would put 250 to 300k on each and really preferred the VW B1 inline setup. Loved the German/A2s as well. The '85 Jetta diesel was the best car VW ever made IMO; retired one @420k, 44 mpg every tank. I was never interested in Audis as they were too $$$ and had way too many accessories, too much $tatu$/comfort/complexity compared to a VW. I took my son to Germany in '98, we visited all the car factories and auto museums we could in 3 weeks, one of which was the Audi factory in Ingolstadt. Unbelieveably complex; beautiful. We did the tour 2x. Back then a customer could watch their car built and drive it out the door. Anyway like I said being a diesel only guy, I always dreamed of an AWD diesel built simply.
I assembled a '99.5 Jetta TDI in '08 that needed a motor, and did a lot of mods to it; 149hp/268lb/ft, gets 48 mpg like clockwork. Even with the Shine suspension it's just bland & Honda-ish, handles like her a** is too fat, I'm sorry to say. My B4 Passat TDI; another VW treasure; I adored, but like all VWs it started to rot.
FF to 2010 when I discovered the 01A trans with its universality of engine choices; the Audi B3 with its inherent rust-proof, safe, innovative/timeless body, the existence of Motorgeek, and the project was born.
In 2008, I found a factory mechanical 12mm AGK TDI injection pump from a VW LT at a Bosch repair center in Berlin and my GF's 82 year old aunt brought it home for me via Zlinn, Czech Republic. I had it rebuilt again by Giles Gallie @ Performance Diesel Injection and set up for my application.
Audi B3s have become very affordable and I bought my first one an '89 80q last fall from a
fellow Geek. I got it running well, then found the project car in CA.
A 1991 80q http://www.motorgeek.com/viewtopic.p...lacier+blue+80
I've always done my own car work and have never had a garage; this time I have a shed roof kind of space and an old pool shed for cover as well. Working outdoors adds a sporting nature to the challenge of the swap! Thanks all who've put up with my questions and requests.
I want to make the car simple to maintain so the power steering and ABS is nixed as well as the driver electric window changed to manual regulator. The other list of parts includes JH shifter, EFI solid shifter linkage, intercooler & tubing, 034 Delrin CA bushings, 034 solid subframe mounts, fuel filter bracket, new Bilsteins HDs, A4 v6 trans., Urq rear diff., solid rear diff mount, rear driveshafts w/ 108 inners for the Urq diff., Spec. Stage 1 clutch & pressure plate, TDI starter, K14 turbo. I'm using stock 4 cylinder parts for the radiator & motor mounts.
One of the major parts to this swap is creating a 4cyl quattro subframe that only exists in EU.
I've decided to use stock 4cylinder mounts which are part of the subframe on B3 4cyl. cars. I cut the engine mounting "tabs" from a 4 cylinder subframe and am having them welded them onto a 5cyl quattro subframe. (I haven't a welder)
4 cylinder subframe
5 cylinder quattro subframe
Measure twice ; weld once.
Revised subframe (crappy pic, sorry)
First step on the new motor was changing the oil pan. I had 2 choices; stamped steel, or A4 1.8t cast aluminum and I went with the steel. A little less capacity but more road hazard proof; a problem where I live.
I used an oil pan windage baffle integrated in the gasket for the bottom end. Last year I parted my B4 Passat TDI and kept the 1Z motor/trans. I'm using all the ancillary stuff from the old over to the new. This ran beautifully with 215k when I retired it
I'm painting the tin along with the "new" subframe with Urethane moisture curing paint & primer from http://www.masterseriescoatings.com/index/ recommended by a restorer.
The injection pump is on , pump timing set. Stock 80 2.0 flywheel with spec Stage 1 clutch installed.
The engine is ready to go in at this point.
There are many other other details to come. A slightly more complete thread is on MotorGeek:http://www.motorgeek.com/viewtopic.p...574460#p574460
Rich
'91 GlacierBlue Audi 80Q M-TDI 51.8 mpg http://www.motorgeek.com/viewtopic.php?f=6&t=45645 http://forums.tdiclub.com/showthread.php?t=344436
'99.5 Black Jetta TDI, 200k, '02 ALH, 11mm IP, RC3+,Titan/nozzles PDliftpump, Racepipe, OMI, 2.5 SS exh., lower IC , Shine, Panzerplate,52/47
oil_me is offline   Reply With Quote
Old February 19th, 2012, 09:07   #2
oil_me
oil_me's Avatar
Default FTF(for the future)
Reserved for more input.
Old February 19th, 2012, 09:14   #3
markd89
Cool project!
Curious to hear how the M-TDI performs for you -- economy, performance and smoke..
1978 VW Bus 1Z TDI Build thread: http://forums.tdiclub.com/showthread.php?t=308793
markd89 is offline   Reply With Quote
Old February 19th, 2012, 10:06   #4
oil_me
oil_me's Avatar
I want to stay well under the engine and ip's maximum performance potential to preserve it for the long run. I'm acutely aware of the debate between the "mech." and the "elec." camps regarding controls on the pump. You know what I mean I'm sure. My quest for simplicity leads only to this pump, come what may. I have 20 years experience with IDI diesels and crave and admire their tombstone reliability. I've rebuilt 2 IDI pumps completely and successfully, but TDI pumps have higher internal pressures and are trickier to set up. This pump was tuned by Giles. He's worked out mods that are worth every cent. The 12mm head puts out a larger amount in the same window as a smaller head so in theory I need boost as early as possible. I don't know if this IP has a "low smoke" feature for emissions or not. It's wait & see. I have 2 K-14 turbos, one from an AAZ and one from a 1.6 Ecodiesel.The Eco K14 has smaller wheels, different wastegate opening specs.; we'll see which works best. I need a boost gauge and a simple boost controller also.
Rich
Old February 19th, 2012, 19:59   #5
whoabeats
whoabeats's Avatar
Fuel Economy: 21mpg ctd 44mpg tdi
There are quite a few guys in ny with mtdi's experience. I have seen them on this forum and more often on vwdiesel.net. I am also sluggishly working on an mtdi project. My goal is to make my cummins 4bt pump work. Should be spot on with pressures I just need to work out the governor. I have already worked out the pump sprocket. Cept the timing belt cover is a real pain to keep from flexing out towards the belts. Good luck on your project though. I love the idea of a simple awd diesel.
97 dodge 2500 4x4 5 speed CTD, gauges, pump work, valair dd clutch, HD Valve Springs, studded and oringed head, bd super b special turbo, DAP 5x 0.014 SAC Sticks, Devil's Own Water/Meth Injection
2000 jetta, 5speed, egr delete, stealth race pipe koni strt's, tt bushings, 3" exhaust , 17" VW Arietta wheels
whoabeats is offline   Reply With Quote
Old February 20th, 2012, 06:51   #6
oil_me
oil_me's Avatar
Originally Posted by whoabeats View Post
There are quite a few guys in ny with mtdi's experience. I have seen them on this forum and more often on vwdiesel.net. .....................
vwdiesel.net. is where I started with the m-tdi idea. There are some dogged souls on that site who did all the experimentation & research to bring it to the light of day. Kudos to those guys.
David Marshall (Go Faster) & Tintin are the 2 individuals who brought the AGK pump to my attention.http://forums.tdiclub.com/showthread...=167583&page=2
Thanks for the input and I wish you all the luck and good fortune you need for your project as well.
Old January 6th, 2013, 20:58   #7
oil_me
oil_me's Avatar
The car's been on the road since September and I've had all the updates over on MotorGeek http://www.motorgeek.com/viewtopic.php?t=45645 for the mostly Audi content and did not have the time to post on both, sorry.
Here's a picture of the car today.
We have about 8" of snow from 2 recent storms and it's been fun. The engine compartment;
The glow plug relay fits where the fuel pump relay was. I had to run two wires for the temp sensor and the GP light and I used the now unused ABS light for that. I used the "O" terminal on the back of the fusebox that is a large spade terminal that connects internally to the relay. This is the intended GP output for the turbodiesel version of this car. I used the ABS 4.0 battery wire plugged on instead. That brought the hot GP source to the engine comp. via the ABS plug without running new wires; the other wires were in place. It works perfectly; the car started without a single misfire or smoke cloud @ 0 the other day. I switched to a 16" VW Dasher steering wheel for better leverage with the manual steering rack.
I swapped on an Audi turn signal cancel tang as they're in different positions and the horn ring for a spring loaded button from the Audi wheel. As far as mileage the past three tanks were; 39 mpg, 41.9 mpg, and 39 mpg. In that period of time I've swapped the turbo 2x and played with the pump timing about 8 different times; so when I leave the adjustments alone for a time; I'll see what's consistent. As I said before there's other details on the MG site also. This car is my daily driver and I love it. I'll work on the intercooler install when I can get back over to the workshed.
Rich
Old January 7th, 2013, 04:17   #8
v8 coupe
Love it can't wait to see this thing run. I've wanted a quattro tdi for years now.
2003 indigo blue Golf TDI Gone!
81 VW Caddy needing Some love!
91 Audi CQ AKA "Eleanor" my unicorn!
09 Rabbit S now a TDI AWD.
91 200 20vt Avant
v8 coupe is offline   Reply With Quote
Old January 7th, 2013, 05:10   #9
oil_me
oil_me's Avatar
The car's been on the road since September and runs beautifully. It's noisier than my '99 eTDI but I do love the sound of fuel exploding. A symphonic cacophony.
Old September 20th, 2013, 19:12   #10
oil_me
oil_me's Avatar
Here's a big update. Back in June, I installed the inter-cooler finally and plumbed it all into the stock airbox. I readjusted the pump timing to the optimal setting of .80mm lift. It was after I set the timing that I committed a mortal sin.
POP QUIZ A**HOLE;
WHAT HAPPENS WHEN YOU FORGET THE 1/2 DRIVE T-BAR ON THE CRANK BOLT, THEN GO OUT IN THE MORNING TO START IT?
Well it started with a clang; the front mount captured the wrench; it ran for a few seconds until the bolt unscrewed all the way out and the crank pulley fell off. I added insult to injury by trying to start it. Twice. When it didn't start I knew what happened.. AAAAAHHHH. Oh; that sinking, expensive feeling that quickly and thankfully turns to numbness. I just got in my other car and went to work. I couldn't make myself look at it for a week. I thought killed the bastard. I pulled the head to find 2 bent valves, 3 broken lifters. In spite of the easy repair, I opted to buy a new head from ID Parts. It came loaded; with all studs for the exhaust + tensioner stud. New head gasket, head bolts, crank bolt (lol) and now I am back where I started. Needless to say; I'll never use a breaker bar to turn the engine; I use a 3/8 drive ratchet now for all the bolts in the pump timing adjustment so it's not possible to leave it on as I have to switch sockets for each bolt.
Evil done. The #1 exhaust valve was was fully open as you can see the dent is dead center in the lifter (most damaging position)
Piston ghost impression
Cylinder head box inspection
Crank Yank
Car is reassembled
I clearanced the side of a 20v airbox top to change the intake position. I screwed a 2" electrical conduit box connector in with a locknut on the back to hold it in place. It worked slick.
I installed Acetron solid bushings in the front control arm. It replaces an 034 Delrin mount that lasted 4 months. It was badly clunking with fore and aft movement; on accel & decel as well as large low speed bumps. The Acetrons were designed with a thrust washer to minimize wear as well as being harder, made with graphite, etc. http://forums.quattroworld.com/9080/msgs/39119.phtml
The last 2 tanks of fuel were 46.8 mpg and 45.5 mpg. It runs excellent. I've put 11,000 miles on the car since last September and it's my only DD at this time. I'm still working to reduce and minimize vibration; I replaced the solid poly
rear diff mount recently with a solid rubber one. I must install a braided flex pipe after the down pipe in place of the hollowed out cat as well. Another plan is to bolt the subframe balance weight from my '96 Passat TDI somewhere on my car to help reduce vibration resonance in certain rpm ranges.
I'm more content with the car as of late.
Rich
Old September 7th, 2014, 08:23   #11
oil_me
oil_me's Avatar
This is an overdue update. The car has 20k miles since the original swap. I purchased a proper awd 01A TDI transmission from Frans back in February of this year and just completed the installation. The difference in the gearing is miraculous. Each gear has a much broader range of useable power. The nasty, annoying vibration is now unnoticeable. I have to put some miles on it to get mileage figures. The previous V6 gasser trans. had a best of 47.5 mpg. I'm hoping for low to mid fifties. The new driveability is more important though. It feels like driving my former Passat TDI. More details are here:http://www.motorgeek.com/viewtopic.php?f=6&t=45645&p=706413#p706413
Old March 16th, 2015, 14:49   #12
paulpas
I just want to keep updated on this.
paulpas is offline   Reply With Quote
Old May 18th, 2015, 07:05   #13
oil_me
oil_me's Avatar
I filled up on Friday before a long drive; first tank to reach 50.3 mpg with mixed country driving. The injection pump timing is now .945 mm. The car ran beautifully on a 580 mile round trip to the Carlisle, PA Import & Kit car show this weekend. The car pulled those long PA hills @ 75mph on cruise control at a steady 12 psi boost. No smoke. I'll fill up this week to confirm this mileage again. The engine now has 30k, uses no oil between changes.
Updates are over at The Project Pad http://www.theprojectpad.com/viewtop...1529&start=150
Old June 21st, 2015, 09:56   #14
oil_me
oil_me's Avatar
I filled up on 5/18/15; 16.7 gal in 835 miles for exactly 50 mpg. Filled again on 6/15/15; 17.6 gal in 872 miles for 49.5 mpg. It seems to be consistent with the variations in my driving conditions. I finished my afterglow timer circuit last month and it works exactly as planned. I used a 5 minute mechanical timer switch, a large terminal 50 amp relay from an ABS pump, and a lighted rocker switch. I have an LED wired to the glow plug harness so I now know when the plugs are actually on. There's 2 other switches wired to relays for the coolant glow plugs for quick heat and warm-up in the very cold weather (like last winter). I adjusted the LDA pre-load spring last month; I'm going to return it to the previous position as it's a little smokier now on hard acceleration. Odometer says 197,000; been 30,000 since swap and the engine's broken in and eager to run.
Old June 21st, 2015, 13:55   #15
markd89
Cool car :-)
1988 audi 80 quattro to pd130 jjordan11 TDI Conversions 222 August 11th, 2015 01:28
Looking to Trade: 1991 Audi 80 quattro near Buffalo, NY Double J TDI Cars for Sale/Wanted 5 May 6th, 2011 20:31
Audi 80 Quattro diesel conversion in OR (not mine) v8volvo Other VW Group TD(I)s 0 April 3rd, 2009 17:47
1988 Audi 80 non quattro to TDI can it be done? merkerguitars TDI Conversions 0 October 2nd, 2006 12:44
audi Quattro TDI??? jeffh Other VW Group TD(I)s 7 April 7th, 2003 19:45
Page generated in 0.16315 seconds with 13 queries
[Output: 149.76 Kb. compressed to 126.62 Kb. by saving 23.14 Kb. (15.45%)]
