Old June 12th, 2014, 17:10   #1
kulsh
Unhappy Injection Pump Timing Jumped
My 1998 Beetle injection pump jumped time. I was very lucky, that belt was very worn it could of been alot worse.
My question is do I just put the injection pump back to the pin hole when I put a new belt on Or is there a BTDC for the pump?
I just bought the car and I didnt know how bad the belt was. I was to busy trying to get it to run.. LOL
kulsh is offline   Reply With Quote
Old June 12th, 2014, 17:26   #2
whitedog
You want the crank at TDC, the locked at TDC #1 and the pump pinned at TDC #1. The cam gear will be loose and the three bolts on the injection pump will be loose, THEN you tension the belt.
But do you know if the cam jumped time at all, or was it just the injection pump?
Old June 12th, 2014, 18:10   #3
kulsh
Whitedog so right now the pump is 180 degrees out I just have rotate it so I can put the injector locking pin in place?
Old June 12th, 2014, 19:12   #4
jettawreck
jettawreck's Avatar
http://pics2.tdiclub.com/pdf/a4timingbelt.pdf
2004 Cadillac SLS (wife's)
jettawreck is online now   Reply With Quote
Old June 12th, 2014, 20:04   #5
kulsh
Thanks great wright up
Old June 12th, 2014, 23:49   #6
Jettascuba
Rotate the crank once more...
Silver VW Jetta A4 TDI 2002 AHF, 421 000km, MAF and EGR delete
(VCDS Hex + CAN, ALH/AHF tools, BRM/BXE tools)
White VW Jetta A5 TDI BXE, 505 000km
Jettascuba is offline   Reply With Quote
Old June 13th, 2014, 13:44   #7
whitedog
At this point I don't know what to tell you. Are you sure the cam is locked at TDC #1? Is the crank at TDC #1? If so, where is the injection pump?
Old June 13th, 2014, 14:03   #8
Jettascuba
Can't see why the IP will jump time, turns easier than the cam sprocket.
I am sure your cam is not locked at TDC. Cam lobes pointing upwards.
In fact, I wonder if anything jumped time...
Old June 13th, 2014, 14:19   #9
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
STOP - Keep away from the car until you've done some reading on your new car (welcome to TDI Club!). You have an early model A4 platform with the ALH (VE) motor.
The long process described in the link in Post #4 will explain how the timing must be set.
I'm assuming you had the belt jump the pump sprocket, not the actual pump jumping time.
If you had no interference collisions (valves, pistons, carnage) consider yourself a lucky person.
Old June 13th, 2014, 16:33   #10
dieseldrive
TDI(s): 2001 Jetta
IP's will sometimes jump time before the camshaft because the belt engagement is much more on the cam than the pump (the belt is engaged with many more sprocket teeth than the pump). Have not seen it happen many times on TDI engines, but it used to happen on the IDI engines quite often (if the belt is ran dangerously loose).
dieseldrive is offline   Reply With Quote
Old June 13th, 2014, 17:27   #11
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
The number of teeth engaged is only one (small) consideration. I'd expect that the CRANK jumped and that the fuel pump AND cam didn't jump.
The crank has even fewer teeth engaged in the belt than either the pump or cam, the crank is driving (rather than being driven by) the belt, plus there is tension on the pump side of the crank only. The crank is trying to push the belt towards the cam. There's an intentional reason the slack tensioner is on the lowest tension section of belt.
The pull of the belt from the crank plus the drag on the belt by the cam resistance make the engagement on the fuel pump sprocket quite secure, secure enough that I'd wager it's more effective than the pump pulling on the belt at the cam and only the (relatively) slight spring force of the tensioner on the other side of the cam sprocket.
Svante Arrhenius 1896
Old June 14th, 2014, 06:09   #12
dieseldrive
TDI(s): 2001 Jetta
Good points, but I am referring to the percentage of the pulley circumference that contacts the belt, the pulley wraps around more than half of the crank sprocket, nearly half of the cam sprocket, and less than half of the IP sprocket. Keep in mind also that the IP does create significant drag on the belt (takes upwards of 5 hp to turn it at full load).
Old June 14th, 2014, 06:58   #13
jettawreck
jettawreck's Avatar
The circumference of the pulley/sprocket is what determines how much contact area there is. Slipping/shearing belt "teeth" is very common on the crank sprocket, such as when the tensioner fails.
I know every now and then someone gets "lucky" and a TB slips on the IP, but usually after they get into the job most are not that fortunate.
Old June 14th, 2014, 07:14   #14
Jettascuba
Good information, thanks.
injection pump timing biggrobb762 TDI Power Enhancements 2 September 6th, 2013 16:05
Injection pump timing...need help! 3milliondollardiesel Other VW Group TD(I)s 1 April 14th, 2013 19:21
Might have jumped timing..... Neukom720 VW MKIV-A4 TDIs (VE and PD) 21 November 19th, 2011 07:05
injection pump timing after timing belt change Anderson3377 VW MKIV-A4 TDIs (VE and PD) 10 March 21st, 2010 18:52
40Kbelt on 80Ktensioner? (Water pump failed -->Timing belt jumped. Sounds/etc) Achoo VW MKIV-A4 TDIs (VE and PD) 14 July 12th, 2002 00:48
Page generated in 0.17492 seconds with 11 queries
[Output: 116.67 Kb. compressed to 97.23 Kb. by saving 19.44 Kb. (16.66%)]
