Old June 28th, 2012, 00:43   #1
makos101
makos101's Avatar
Default Electrical Problem with Voltage Spikes. Video
Ive been having this electrical beeping problem on start up. I finally got my dads scan gauge in my car. Here is a video of the voltage spikes and the dash esp, abs, and break lights flickers as well as all the interior lights.
http://www.youtube.com/watch?v=d_0tBEymTg8
Is my alternator bad? What could be causing this?
Thanks Guys
Malone Stage 3 Custom tune, SBC stage 2 Endurance, Sprint 520s
makos101 is offline   Reply With Quote
Old June 28th, 2012, 10:54   #2
JB05
Fuel Economy: 43/41/40
That 16v spike is too high; could be a faulty voltage regulator; but I'm just guessing.
JB05 is online now   Reply With Quote
Old June 28th, 2012, 16:09   #3
makos101
makos101's Avatar
thanks you, Im pretty new to alternators and voltage regulators any more advice guys would be amazing
thank you
Old June 29th, 2012, 16:19   #4
jcrews
jcrews's Avatar
TDI(s): All gone
The SG is too slow. Can you check the voltage at the output terminal on the generator? It's the one with the large black wire connected to it.
Can you check for voltage across any of the main fuse links, and for voltage between the battery (-) and the engine block? Make sure you use clean test points.
Basic regulator circuit test - the "battery" lamp will illuminate when the engine isn't running. If the lamp flickers during running or extinguishes when the engine is off, the regulator is probably bad.
jcrews is offline   Reply With Quote
Old June 30th, 2012, 12:31   #5
makos101
makos101's Avatar
Thanks for your response! Whats SG? Do you mean check the output on the alternator terminal?
Old July 1st, 2012, 10:53   #6
jcrews
jcrews's Avatar
TDI(s): All gone
Scan Gauge, and yes.
Old July 1st, 2012, 10:59   #7
josh8loop
josh8loop's Avatar
Fuel Economy: 45 MPG City with the previous 01M, 5-speed 60+ MPG City. Always searching for ways to make it better!!
SG is your Scan Gage. Yes, see if you can test the voltage right at the battery terminals with a decent quality digital voltmeter. If it turns out to be the voltage regulator I believe they can be replaced with the alternator installed in the car. They aren't too expensive either:
http://www.ecstuning.com/Volkswagen-...ulator/ES2792/
That link mostly supplied for visual refference. Check the model number/type of your alternator and verify fitment before you order. I have seen good quality german made parts for reasonable prices on Ebay as well.
Here is what the voltage regulator looks like installed on the alternator:
http://www.justanswer.com/vw-volkswa...jetta-gls.html
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 60+ MPG City.
Now have Nokian Entyre Low RR tires!
josh8loop is offline   Reply With Quote
Old July 2nd, 2012, 09:38   #8
josh8loop
josh8loop's Avatar
I just looked at a junk alternator I had laying around to see what it takes to get to the voltage regulator. Once the battery cable, and control harness is removed from the alternator all that is needed is a 13mm, 15mm, and a phillips screwdriver. Once the plastic alternator shroud piece(also contains some unknown circuitry) is removed by taking off the 13mm not, and 15mm nut, the voltage regulator can be accessed by removing the phillips screws. I am reasonably sure this can be done in the car. The coolant inlet pipe/flange may need to be removed however.
Old July 2nd, 2012, 23:20   #9
makos101
makos101's Avatar
Hey guys thanks for all the advice. Ive tried a few voltage tests and cleaned the alternator ground.
When driving the voltage on the Scan gauge stay at 14 volts. But when idle the voltage drops to 13.5. Is 13.5 low?
Does this sound like it could be the pulley, alternator, and regulator? The car has 170k miles and they have never been replaced.
Thanks for all the helpful advice.
Old July 3rd, 2012, 10:56   #10
JB05
13.5 does not seem too low for this time of year. I have a volt meter which is pretty accurate that is plugged into my cig. lighter and it too reads ~ 14v while driving and just one or two tenths lower at idle. I have no accessories ON and my DRL's are OFF.
Old July 9th, 2012, 00:50   #11
makos101
makos101's Avatar
Hey guys I replaced the alternator yesterday. So far there has been no beeping/flashing dashboard lights and the voltage has been steady from 13.7-14.0. There also has been no voltage spikes that go down to 12.5 and then up to 15 when the car is in idle and the lights don't dim when I touch the breaks.
On examining the old alternator the pulley spins freely, there is nothing touching on the inside of the old alternator. When i spun the new rebuild alternator you could feel a light brushing inside.
Voltage spikes, triggering fault codes kaellis VW MKIV-A4 TDIs (VE and PD) 6 March 6th, 2013 06:52
Voltage Spikes up to 19+V tscott1224 VW MKIV-A4 TDIs (VE and PD) 13 February 7th, 2012 19:34
A/C electrical short / no voltage nvr-enuf VW MKIV-A4 TDIs (VE and PD) 1 August 5th, 2010 12:15
My TDI's electrical problems - voltage regulator? callawaytdi TDI 101 6 July 22nd, 2010 10:20
Problem with Boost Spikes str8edg Upgrades (non TDI Engine related) 8 December 22nd, 2003 02:32
Page generated in 0.16494 seconds with 11 queries
[Output: 103.89 Kb. compressed to 87.66 Kb. by saving 16.23 Kb. (15.62%)]
