Old December 10th, 2009, 20:15   #1
wgargan
Default voltage, no voltage, wait voltage! uhh no voltage
My electrical system has been acting up. Starting at higher rpm's any where from 2300 to 3000 and sometimes at any random lower roms the battery light comes on. I replaced the voltage regulator and that did not cure it. After searching the posts here I checked the tensioner and it goes up and don. When it comes up there is no voltage when it goes down there is voltage. What makes it go up and down? From all the input in the searched posts i gather I have a bad alternator pullr and/or a bad tensioner.
does this sound about right?
current hobby: 2000 golf TDI black
old hobbies:1993 f250 veggie powered, 1980 300 td-t mercedes veggie powered, 1971 VW camper, 1973 Vw camper, and 1993 chevy pickup
wgargan is offline   Reply With Quote
Old December 10th, 2009, 20:42   #2
jcrews
jcrews's Avatar
TDI(s): All gone
It's either a bad pulley or a bad tensioner. You can check the pulley easily by spinning it with your hand while using a piece of plastic to stop the alternator fan from spinning.
jcrews is offline   Reply With Quote
Page generated in 0.11556 seconds with 10 queries
[Output: 48.10 Kb. compressed to 44.13 Kb. by saving 3.97 Kb. (8.25%)]
