Hi, did a search but couldn't find a thread about the specific issue.
I've an Audi A4 with a 110bhp AFN engine (European model). It has previously been chipped to around 155bhp.
After a blown turbo and getting the car back up and running (no engine damage done, cleaned intake manifold and intercooler and got reconditioned turbo), I was scanning the car for faults with Vag-Com and came up with:
00550 Start of Injection Regulation (Control Difference Intermittent).
After using the instructions on RossTech and here I checked my injection pump timing and found it to be at around 150 (spec about 45-65). After a few tries I got it to just above spec (68) but, while the car is running very smoothly, it will not start any more. To get it to start I've had to put the injection timing back up to 135.
Not sure if this fault code is even for this problem but anyone any info on what the Vag-Com fault may be and also why the car won't start when I put the pump timing in spec? I've a PiperCross air filter, the fuel filter was changed a few weeks ago, and as I say, the intake manifold and intercooler are spotless.
Thanks in advance.
PS. The flywheel is also in perfect condition as I fitted a new clutch and gearbox a couple of weeks ago also.
Thanks in advance.
