Strider17
- Joined
- Apr 5, 2016
- Location
- Hamilton, Ontario, Canada
- TDI
- Beetle(sold) MK4 Golf TDI(sold) Mk4 Jetta TDI(parted out) MK4 Golf GTI w/ALH swap (built then parted out) 2015 Passat TDI Highline (current)
Hey everyone. question for those who have done this swap.
Need help with the wiring:
the auto tranny only had 3 connectors.
1x 8 pin
1x 1pin (starter?)
1x MULTI pin
how do i go about wiring the reverse lights and starter interlock. here are the 3 connectors. I have searched everywhere and cant find a proper answer.
the only thing i have found is the posts below. But i dont understand them since the auto tranny only has 3 connectors:
So what it looks like, THIS IS FOR THE MK4 PD ONLY
There should be a VSS connector somewhere on the engine harness it will have a black/white, white/blue, and brown wire.
These should already have the correct pins.
Black/White should have continuity to fuse S7 in the drivers side door. it's a 10A fuse. This goes to Pin 1 on the VSS connector
White/Blue should have continuity to pin 28 on the small connector to the ECU This goes to pin 2 on the VSS connector
Brown should have continuity to ground. This goes to pin 3 on the VSS connector.
"""""""""The reverse switch will connect on one side to the black green wire and the other to the yellow blue wire, which leads to the interior of the car (the PN relay) which should be tied to the Black Blue wire to the reverse lights.
The Blue/Purple wire is the wire that goes between the ECU pin 54 and TCU pin 56. This will be tied to the red grey wire that will connect to the clutch switch. The other end will need to connect to pin 43 in the ECU. The clutch switch will connect to the black green wire.
starting interlock should be the same as the ALH directions, as most of the wiring is the same. YMMV
ok, I just pulled up the instructions and I think I found an error in the wiring schematic. You need to use the picture on page 40 of the ECU connector for the proper wire location. The wiring schematic that is earlier in the how to show the number "68" so if you count over to 66 you are in the wrong location. The picture of the ECU connector on page 40 shows the correct representation of the wiring locations. USE THAT TO FIND WHICH WIRES GO WHERE!!
2005 Jetta Wagon TDI 5 speed swap wiring
Followed instructions for starter interlock and reverse wiring from Boertje’s Auto to 6 speed
swap write up.
Cruise control was followed except for the following differences.
I followed the yellow/blue wire from the 175 relay to the TCU- T19/68 (continuity check).
Found Blue/Violet wire at TCU- T63/68 that had continuity with ECU- T90/94. I moved the
ECU side of this wire to ECU- T43/94. I then connected the TCU sides of the Blue/Violet to the
Yellow/Blue.
VSS Wiring- I found continuity from the blue cluster connector (need to remove instrument
cluster), green wire T28/32 to a Blue/Violet wire on TCU- T56/68. I then ran a length of wire
from the Blue/Violet at the TCU through the plenum and then into the engine bay with the group
of wires on the driver’s"""""""""""
thank you
1x 8 pin
1x 1pin (starter?)
1x MULTI pin
swap write up.
Yellow/Blue.
thank you
