Intermittent Power Loss--my "Hauntings"
ncbound44
New York
1991 VW diesel, 2002 Jetta TDI
Hello! I have a 2002 Jetta TDI that has intermittent power surges AFTER I drive. Once the key is removed, or turned off, the power in the car (electrical supply that is) flickers. At times, locks try to engage and re-engage but do not fully. The key fob will not work. This continues until I jiggle my negative battery connection. Some times this takes 1 times, sometimes 20. When driving, sometimes before this happens, by brake light and ABS will flash and beep at inconsistent rates. I then know I am going to have my "hauntings", if you will. This is not a guarantee. There are no noted changes in electrical power as I drive. After the surges stop, i can touch the brake or turn the ignition and lose partial electrical power and cannot start my car---I then go and jiggle the negative connection. I have cleaned this connection and it helped for about 4 weeks. this has been on going for years and getting worse. The more it happens the longer it takes for "jiggles" to make it better.
At baseline, no abnormal voltmeter reads. Any thoughts?
flee
Chatsworth, CA
2002 Jetta GLS wagon
Both battery connections should be clean and tight enough that no amount of 'jiggling' should affect anything.
ncbound44
New York
It shouldn’t.... but they are clean and right and no wiggle room....i just replaced my ignition switch... that was suggested by several people i guess I’ll know sometimes between now and in a few weeks!
