Around 350-400 EUR with 10.000 -20.000 km milleageSlight off topic, how much is that BMW turbo in Europe? I would like one
The compressor is ally. However going to weld the turbo directly to manifold. Cast iron 2 cast iron welds ok ?It is almost trivial to cut and re-angle the outlet pipe. The casting welds nicely.
People here have done this on various projects.The compressor is ally. However going to weld the turbo directly to manifold. Cast iron 2 cast iron welds ok ?
But I''ll need to weld a a steel flange on manifold for that vband and steel 2 cast iron are prone to crackCast iron can be welded however they are different grades of casts- most Garrett casts are weldable- some are even cast stainless steel (gtb2060vklr, etc). I would use the v bands supplied on the housings, they are plenty good enough for what you need. I actually seen a lot of welded turbos crack from the joint due to thermal stress, keep it simple !
Al
We have entered the 21st century!You cannot weld cast iron. There is a process called brazing, but I don't think it will hold up for your location.
