Old October 22nd, 2018, 13:39   #16
chaos88
Well, unfortunately the old injectors had to come out.
Took me a while to get replacements. I just installed them over the weekend and now the car is up and running. I'm glad I had the VCDS to be able to code them in. I wonder if I could somehow clean them.
Anyways it's all good so far, no leaks and it appears to be working normally.
I'm still not sure if it's the quality of the diesel fuel or the piss poor VW design for the injection pump. Anyhow I started to use an additive for each tank of fuel. I can't go through this ordeal again. It's just to expensive and time consuming.
On another note, I see that governments are starting to take action in phasing out diesel cars. At least that is the case in Europe. I think that's a shame. Diesel is still the most economic and efficient transportation.
Anybody heard anything about that in North America?
BR,
Dumitru
chaos88 is offline   Reply With Quote
Old October 22nd, 2018, 16:25   #17
BRIAN427COBRA
My new to me 2015 Passat with 28k miles suffered a HPFP failure today, had it towed to the dealer, should be back on the road next week, I emailed 2micron asking if he was still making his kits
If You Don't Have a Panzer SkidPlate, Get One ASAP
BRIAN427COBRA is offline   Reply With Quote
Old October 23rd, 2018, 09:10   #18
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
I dont think they were ever made for the 2015 CVCA or CRUA engine codes.
Fixmy59bug is offline   Reply With Quote
Old October 23rd, 2018, 14:17   #19
BRIAN427COBRA
I think youíre right, but I also think I can adapt the 2microntech filter to the HPFP, and possibly use the NickTang setup to filter the return fuel, or just use 2 NickTang kits to do both and eliminate the factory fuel filter assy all together, when I get my car back in a week or two Iíll know for sure, I may just park my Passat and put another 200k on my 03 Jetta.
Old October 23rd, 2018, 14:40   #20
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
That is the best backup for a CR car: a VE or PD.
oilhammer
www.cardocautomotive.com
Fuel Pressure issues, HPFP hasn't died - P0087 and P0088 DTCs JSWTDI09 VW MKV-A5 Golf/Jettas 17 October 4th, 2017 12:16
B5.5 died while driving like out of fuel but has a half tank. KnoxWilson VW B5 Passat TDIs 19 October 25th, 2016 09:19
High Pressure Fuel Pump (HPFP) failure - not blamed on fuel birkie VW MKV-A5 Golf/Jettas 80 October 16th, 2014 11:03
2013 HPFP Failure - original tank of fuel Sohappy VW Passat Family (NMS and B7) TDIs (2012+) 45 November 16th, 2012 20:42
in tank fuel pump died tdi_sport VW MKIV-A4 TDIs (VE and PD) 14 May 14th, 2007 02:55
Page generated in 0.16480 seconds with 11 queries
[Output: 71.21 Kb. compressed to 63.10 Kb. by saving 8.10 Kb. (11.38%)]
