Old August 30th, 2018, 14:00   #1
igiveup
Default Spare tire size
Bought a 2015 Passat from a used car dealer. These numb nuts put a 15" Spare in the back. 195/65/15 Besides the tire size being wrong I'm pretty sure it wouldn't clear the calipers in the front.
Does the Passat normally come with a donut or a full size spare?
igiveup is offline   Reply With Quote
Old August 30th, 2018, 14:04   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Does the placard show the spare tire size? Some do.
Edit: I do not have an NMS Passat here at the shop today, but the two newest dubs I have, a 2009 NB and a 2007 Rabbit, both have the spare tire size on the placard under the standard tire sizes, I suspect your car does too. Pretty standard fare.
oilhammer
www.cardocautomotive.com
Old August 30th, 2018, 15:35   #3
Jedadiah
Jedadiah's Avatar
My 2015 needs at least a 16” spare, and it doesn’t have much wiggle room.
Jedadiah is offline   Reply With Quote
Old August 31st, 2018, 05:44   #4
740GLE
215-60-16 is the proper size and a 16" is needed to clear the calipers.
Sadly the NMS comes with a compact spare our '12 and '15 did, so sounds like someone poached that one and the dealer was trying to make you whole.
See if the dealer can make the situation right, if not, hit up your local tire shop and see what they can do. For our Alltrack (that also comes with a compact spare) I had an old Bioline rim that I had the local shop toss on a used tire and balance it, cost me $40.
Old September 2nd, 2018, 19:49   #5
igiveup
Thanks, I checked it the sticker in the door, looks like it does come with a donut.
Might be better off keep the P7 Pirrelli for my Jetta and find a donut.
Old September 3rd, 2018, 10:52   #6
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
Yup 2015 comes with a donut ( temporary ) spare good for only a short distance and limited speed..
Go back to where you bought it and let them give you the proper one !
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is offline   Reply With Quote
Old September 4th, 2018, 13:46   #7
740GLE
Stock size for a jetta is only 205-55-16, much smaller, don't use that for a spare for the Passat, get a used cheap proper sized tire.
Old September 27th, 2018, 22:32   #8
BroncoAZ
Mine came with a donut, but a full size spare (215/55R17 in my case) fits fine in the spare tire well.
My Commuter: 2015 Passat TDI SE 6MT, Wife’s Driver: 2015 Touareg TDI Lux
Former TDI’s: 2009 Jetta TDI - traded 09/2013, 2011 Touareg TDI - Bought back 2/26/2018
My Truck: 2006 Dodge 2500 4x4 Cummins
Wheelin Rig: 1987 Ford Bronco http://www.supermotors.net/registry/13
BroncoAZ is offline   Reply With Quote
Full Size Spare Tire 1854sailor VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 17 April 12th, 2018 05:35
Weight saving: compact spare available to replace full size spare tire? austi012 Upgrades (non TDI Engine related) 96 July 17th, 2014 11:42
Spare tire size av8or VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 5 July 9th, 2012 10:31
Spare tire size tank weasel Ontario 8 July 12th, 2008 20:26
Will A Full Size Tire Fit in a (A3) Spare Tire Well? Ric Woodruff VW MKIV-A4 TDIs (VE and PD) 10 September 4th, 1999 01:41
Page generated in 0.14822 seconds with 11 queries
[Output: 86.69 Kb. compressed to 74.28 Kb. by saving 12.41 Kb. (14.32%)]
