Old September 30th, 2018, 10:11   #16
jrm
Fuel Economy: 42/52
mite not be the G13 as older TDI's with G12 have the same issue, lucky for us our cars don't overheat- check this out> https://www.youtube.com/watch?v=sG7ni0lEr94
2015 Passat TDI SEL
2013 Passat TDI SE+NAV 48MPG (totaled)
2012 Ram 2500 Longhorn 15MPG tops
2009 Highlander Hybrid aka the HIHY 25MPG
1996 Dodge mechanical Cummins 12V 2500 4x4
jrm is offline   Reply With Quote
Old November 16th, 2018, 08:59   #17
cjwilson78154
Default Just circling back to keep anybody who's interested up-to-date
I took the car back in for coolant smell and leaking coolant behind the heater core access panel. After having the car for 4 days I called to get an update. The service manager says one or more of the heater core o-rings has failed. Mind you, these o-rings were just installed by this same dealer a couple of months ago. They are of course covering it under warranty.
He said he has to dismantle to see why there is an o-ring failure. He offered that maybe one rolled out of it's notch or got cut during the install.
cjwilson78154 is offline   Reply With Quote
Heater Cores from RockAuto.com! RockAuto Vendor & GroupBuy items for sale 0 October 30th, 2017 09:20
How do you clean heater cores? whitedog General Automotive 11 November 25th, 2015 09:05
2014 Passat Engine Coolant Pre-Heater (Coding the engine preheating system) stringbeanbowler OBD Scanners 0 February 7th, 2014 21:30
turn indicator, brake system and failing seat ltz VW B5 Passat TDIs 6 June 29th, 2006 18:04
Coolant heater installed, air in system-problem? nick02 VW MKIV-A4 TDIs (VE and PD) 4 December 16th, 2004 05:13
Page generated in 0.11690 seconds with 11 queries
[Output: 54.34 Kb. compressed to 50.14 Kb. by saving 4.21 Kb. (7.74%)]
