Old February 8th, 2018, 10:34   #16
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
Originally Posted by BroncoAZ View Post
5% rear tint means I never adjust my mirror for bright headlights.
I did not drive my Passat long before I added tinting on all five windows, maybe the rear window being tinted makes a big difference for the auto-dimming.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is online now   Reply With Quote
Old June 27th, 2018, 07:38   #17
Bug
I just picked up a recirculated 2015 Passat SE with sunroof pkg and 20k miles yesterday. I was surprised that it did not have the auto dimming rv mirror. The 2015 brochure shows it as a standard feature on the TDIs. I had it on my 09 Jetta TDI (sold back) and loved it. Is it possible that mine came with it originally and that the original owner swapped it out?
The car does have tinted windows, but we had the rear tint removed by the dealer before we bought because they did such a crappy job it was like looking through smeared Vaseline in the rear view. I think that is why I didn't notice the std mirror on the test drive...
If so, then the electrical hookup should be under the cowling and I could put a stock auto mirror up there?
Bug is offline   Reply With Quote
Old June 27th, 2018, 10:38   #18
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
I do not think it was standard on all TDI's for the 2015 model year. I think 2015 was another de-contenting year.
My 2015 Passat SE does not have it either. (Earlier when I commented, I had a 2014 SE which did have it).
Fixmy59bug is offline   Reply With Quote
Old June 28th, 2018, 06:21   #19
740GLE
Our 15 SEL has auto dimming
Old June 28th, 2018, 11:21   #20
Lincoln
I was also surprised to find that my 2015 doesn't have auto-dimming, since my 2013 had it. Anyone know if it's easy to swap the mirrors? I haven't turned in my 2013 yet, and I'm one of the ones who like the auto-dimming feature.
Lincoln is offline   Reply With Quote
Old June 28th, 2018, 16:13   #21
goodmonkey
goodmonkey's Avatar
IMHO, the VW auto dimming mirrors do not work very well. Three NMS Passats now, two of those driven a bit before tinting, and they didn't work well before either. On the other hand, the Chevy's I've had with auto dimming mirrors work great, and my Silverado the driver's exterior mirror dims based on the rate of the dimming of the internal review mirror. I'd really like to know if the new upscale mirror for the Passats and Jettas works any better.
There is something I'm willing to try though, putting some sort of filter on the daylight sensor on the mirror. There is a sensor on the front facing side that sees how bright things to decide if dimming is active or not. The sensor on the rear facing side picks up light, and the brighter that is the darker the mirror goes, if the front sensor things things are dark. I've played with it some in the daylight, and the mirror can get really dark. I'm not driving enough at night now to think much about it though. In a couple months I'll probably revisit this problem.
2014 Passat TDI SEL (DSG) - 82k, 2007 Silverado Duramax - 425k
Previous TDI's: 1996 Passat TDI- totaled at 394k miles, 1998 Passat TDI - 175k miles, 2012 Passat TDI SE - 41k, 1996 Passat TDI Variant - 327k, 2014 Jetta SportWagon TDI 6MT - 29k, 2015 Passat TDI SEL - 18k, 2006 Jetta TDI 5MT - 261k
goodmonkey is offline   Reply With Quote
Old June 29th, 2018, 10:55   #22
Bug
Default Brochure
That's interesting. The PDF of the 2015 Passat brochure shows it as std on all TDI models...
Old July 7th, 2018, 18:13   #23
reilljp
TDI(s): 2015 Passat
Do the mirrors actually leak fluid?
reilljp is offline   Reply With Quote
Old August 18th, 2018, 16:47   #24
Dan C.
After having my car about two weeks I'll say for certain, the auto-dim feature is not that great.
I'd rather have the dumb manual mirror.
My 05 Merc has auto dimming rear view and outside mirrors. They work well. The Audis probably work well, too.
High end features for a low end budget doesn't always pan out.
'97 B4 Passat 397k sold!
'09 Jetta 6M 200k VW bought back Jan '17!
'05 E320 CDI fast fast, wrecked! rebuilding into a project hot rod
'15 Passat SEL Premium DSG
Dan C. is offline   Reply With Quote
Old August 19th, 2018, 08:29   #25
Jetta_Pilot
You have to add blinker fluid once every two years!
Old August 20th, 2018, 05:37   #26
740GLE
there is an electrical controled fluid in the mirror, that if "broken" can crack and leak or cause splotcheness. we had good luck with our '12 TDI SE and so far so good on our '15 Passat and '17 Alltrack
Old August 21st, 2018, 04:46   #27
saucer
Bit of a threadjack, but I recently had my windshield replaced and the tech couldn't seem to get the plastic cover over the rear view mirror mount to reconnect completely (the part that covers the "arm" of the mirror, to where it meets the windshield). It's technically on, but it's easy to see where the clasp is 1/4" from completion.
Anyone know how to properly close this? I've tried squeezing it shut, but it's not wanting to cooperate...
Old: 2010 Golf TDI, 2002 Jetta TDI
New: 2015 Passat TDI SE
saucer is offline   Reply With Quote
Old August 21st, 2018, 05:47   #28
740GLE
What car is this on? 2010 jetta? or a Passat?
Old August 21st, 2018, 05:56   #29
saucer
Sorry, 2015 Passat NMS
Old August 22nd, 2018, 05:37   #30
740GLE
they prob broke some clips or something
rear view mirror ecmoon3 VW B5 Passat TDIs 5 August 4th, 2015 19:19
Rear view mirror HBRD_KLR VW Passat Family (NMS and B7) TDIs (2012+) 4 October 25th, 2012 08:17
Rear View mirror AlanTDI VW MKIV-A4 TDIs (VE and PD) 7 November 27th, 2011 09:16
Rear view mirror? DanisTDI TDI 101 13 September 26th, 2006 09:03
Rear view mirror Kubla84 VW B5 Passat TDIs 0 July 15th, 2004 07:22
Page generated in 0.15903 seconds with 11 queries
[Output: 126.07 Kb. compressed to 104.98 Kb. by saving 21.09 Kb. (16.73%)]
