Old May 6th, 2014, 19:48   #31
rojovilla
It's baaaaacckkk! Stupid RNS-510's.....
Got three photos of three different freezes with two different cards, and now it's time to get a case manager involved AGAIN! This time I'll request beforehand that I get the newest unit. Keep ya'll posted...
Sent from my SM-N900T using Tapatalk
rojovilla is offline   Reply With Quote
Old May 6th, 2014, 20:36   #32
mattfrayage
mattfrayage's Avatar
Surprise!
LOAD"*",8,1
when all else fails, Blame North Korea, for they are ALWAYS up to no good
my VW vids:http://www.youtube.com/playlist?list...lYQboyuttrsJ5e
mattfrayage is offline   Reply With Quote
Old May 8th, 2014, 14:12   #33
rojovilla
Nice one, Matt!
Old July 17th, 2014, 09:06   #34
skateboy918
TDI(s): 07 VW GLI
The problem isn't the SD card or the slot. It's the flex cable INSIDE the unit.
Its bent in a few ways so it fits in the unit but what happens is it the vibration cause it to come slightly loose from the connection to the unit so sometimes it reads and sometimes it doesn't.
It depends on how the unit is assembled - most are probably not snag on the frame of the unit so that's why most units don't see this issue but the few that do see this issue, I think it's worth taking the unit aprt and fixing the cable (if you're out of warranty)
skateboy918 is offline   Reply With Quote
Old September 24th, 2016, 19:14   #35
22positions
Post
Originally Posted by mrmoto35 View Post
I was just searching around and found this
http://www.my-gti.com/719/difference...nd-the-rns-510
Looks like 32gb is max cap. No big deal 32gb is plenty music from one source
My 510 actually plays a 64gb sdxc card - I can't afford the 128 gb card at this time. It gave me trouble at first and rejected the card. This was due to the card being pre-formatted as Fat-32. Turns out, VW runs MS-DOS (Fat-32) which apparantly is different from Fat-32. After formatting the card, it was recognized by the unit and started to play the media I stored on it.
22positions is offline   Reply With Quote
Old September 25th, 2016, 08:12   #36
Rico567
Our RNS-510 will do this periodically. The error comes up, but then the program just goes ahead and plays. Since it doesn't really affect it playing, we've never had anything done about it.
[URL=http://www.fuelly.com/driver/rico567/passat]
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
Old September 25th, 2016, 08:19   #37
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
I did have a problem which I had posted here in this forum as well, but I found the solution to it myself. It was a problem uploading waypoints to the GPS. I had tried different SD cards and ALL were formatted using Windows to Fat-32.
There is NO difference in MS-Dos Fat-32 or Windows Fat-32. The only difference is that these days very few people still can use or work using DOS. Even if you formatted to Fat-16 it really became Fat-32 using DOS.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is offline   Reply With Quote
Old October 8th, 2018, 19:46   #38
TDI321
TDI321's Avatar
Fuel Economy: 50mpg@75mph, 68@50, 37@95
https://www.sdcard.org/downloads/formatter_4/ this is a free SD card formatting program. Yes, the max size is 32gig for FAT32. its not a limitation on the 2015 Passat SEL Nav system with a USB thumb drive plugged into the MDI, but it is on the card slot. 32gig is okay. Mp3 is the bigger limitation. tried everything with a new 128g card and it just wont fire up. Too bad the stereo cant FORMAT the card for you.. that would make too much sense.
TDI321 is offline   Reply With Quote
RCD-510 SD Card Options Collin J Upgrades (non TDI Engine related) 4 August 20th, 2013 02:48
rns 510 help needed for the incompetent with sd card rustycat VW Passat Family (NMS and B7) TDIs (2012+) 16 August 9th, 2013 05:02
RNS-315 and SD Card tonyman TDI 101 0 June 25th, 2013 00:13
RCD 510 SD Card - Ghost MP3 Files DaryllMcK VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 13 March 24th, 2013 09:35
RNS 310-315 SD Card JayT TDI 101 6 January 25th, 2013 12:28
Page generated in 0.14152 seconds with 11 queries
[Output: 89.44 Kb. compressed to 77.32 Kb. by saving 12.12 Kb. (13.55%)]
