P pgdub Well-known member Joined Dec 4, 2002 Location Canada TDI jetta 2001 Black Jan 6, 2005 #1 I have a 2001 TDi and I was wondering if my sway bar is a 21mm or if it is a 23mm sway bar, as I am going to be changing the sway bar bushings? Thanks PGDUB
S SoCalJames Veteran Member Joined Oct 10, 2000 Location OC, CA TDI I no longer own a TDI Jan 6, 2005 #2 According to vw.com, the Golf TDI has a 23mm front and 18mm rear anti-sway bar(s). I'm virtually certain your 2001 is exactly the same.
