Old July 24th, 2010, 13:48   #1
rickheatherley
Default 2010 Golf TDI Wiring Diagram?
Newbie here. I'm about to install a device into the car and need to know which wires are tied to the cigarette lighter so I can tie off of it for my device. Does anyone have a wiring diagram for this model of VW? It would save a ton of time. thanks in advance.
rickheatherley is offline   Reply With Quote
Old July 24th, 2010, 19:26   #2
S_Sanders
Fuel Economy: 41 AVG
Rick,
I've added two switched circuits to my car, one for trailer lighting and the other for my GPS. To make the electrical connections, I used the following products:
http://www.amazon.com/gp/product/B00...ef=oss_product
In the fuse panel that's inside the left edge of the dashboard, there are several unused fuse locations that have a connection for power, but no connection for an outgoing circuit. Using a test light, it is very easy to locate switched circuits. As I recall, rows of fuses are either all switched or battery power. Just be careful not to pull too much power from these connections. Since you don't know the capacity of the wire you're using, extra care is required.
Since I installed my trailer wiring, I learned that if you remove the battery, you can gain access to a through-firewall wiring grommet that you can use to run a wire from the main power panel under the hood to the inside of the car.
2010 Golf TDI Coupe, 6 Spd Manual, Sunroof, Gray
2012 JSW, DSG, Black
S_Sanders is offline   Reply With Quote
Old August 2nd, 2010, 01:27   #3
rickheatherley
Hi there S Sanders. Thanks a million for your reply. I'll give this a try. We have a local auto supplier that has similar parts so I'll try to find the access through the firewall and use a similar part. Will let you khow how it goes. thanks
Page generated in 0.14677 seconds with 10 queries
[Output: 53.41 Kb. compressed to 48.29 Kb. by saving 5.12 Kb. (9.59%)]
