Old July 14th, 2010, 17:28   #1
PDJetta
PDJetta's Avatar
Default I Joined the Busted Seat Spring Club Today
On the way home from work today, driving along and BAM! Sounded and felt like something huge slammed into the undercarriage of the Jetta, but I was puttering along in traffic at about 10 MPH. My wife was with me and she jumped and screamed, "What the hell was that!" I just went, "Ahh it finally happened", and grinned at her. She thought I was nuts. Good thing I read the posts here about the seat spring breaking with a deafining bang! Otherwise I would have searched like crazy for undercarriage damage.
Oddly, both seat lifts still work fine and I did not find a big spring rolling around under the seat.
Update: Yes, I found it. Passenger's side. I showed it to my wife and told her this is what she heard and felt busting loose under her seat and she said, "God, I have to get back on my diet!"
--Nate
Old July 14th, 2010, 18:21   #2
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
I noticed one laying under my passenger seat the other day... never heard it, but knew exactly what it was.
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old July 15th, 2010, 06:40   #3
belome
Fuel Economy: 47'ish
Mine was laying on the front floor mat the day after I bought the car used.
Not sure if it came of then or it was hard braking. It doesn't appear broke but my buddy looked and it appears it would require seat removal to replace.
Where is the main thread talking about this?
The only thing I can pass is a fuel stop, but I'm OK with that.
My claim to fame - I was banned from VWVortex!
belome is offline   Reply With Quote
Old July 15th, 2010, 07:09   #4
gforce1108
gforce1108's Avatar
Haven't seen a 'main thread', just lots and lots of 'where did this spring come from?' threads
Old July 15th, 2010, 08:13   #5
hid3
Banned
jeez you boys and gals really need to eat less junk food
hid3 is offline   Reply With Quote
Old July 15th, 2010, 09:32   #6
Powder Hound
Powder Hound's Avatar
Not even funny, hid3.
The mass pushing down on the seat cushion has nothing to do with this. It is merely yet another crappy german engineering decision. The little cast hook that the spring is on is cast, it is brittle, and it can't hold the spring tension. For any of these, it is merely a matter of time before you find the spring.
If you look carefully enough, you will also find a small chunk of metal that looks broken on one end. It is only about 4mm in diameter, and 6-7mm long. The chunk is probably hiding under the seat also, and since very few people are silly enough to remove a seat to look for it, very few people have seen it. Or maybe they all just heard the click as a vacuum sucked it up.
Old July 15th, 2010, 20:09   #7
DSIre
I made the mistake of asking the dealer for a replacement seat frame (it was still under warranty at the time) The replacement parts - the seatback does not sit tight against the seat, so if you put something on the seat, like a map, it falls through.
Best fix? Do nothing. Thats what I did with the drivers seat and it goes up and down just fine
DSIre is offline   Reply With Quote
Old July 16th, 2010, 16:23   #8
rocketeer928
rocketeer928's Avatar
First time I have ever read about this issue. Watch, Murphy's Law will kick in and one of my seat springs will break soon just because I read about it.
2003 Jetta GLS TDI with RocketChip RC5-ASV-Euro tune specific to my performance modifications - Platinum Gray
yo
1970 VW Type 3 Squareback - Cobalt Blue
rocketeer928 is offline   Reply With Quote
Old July 24th, 2010, 14:13   #9
Aquaticmind
Aquaticmind's Avatar
Location: Wheeling, WV via Athens Georgia via, Bainbridge Is. Wa, via Carbondale IL, via Asheville NC
Fuel Economy: good
Thats what happened to me... I found my spring yesterday..
So where does the spring attach? What did it do, and should I try to replace it??
2003 Wagen, 2" lift, auto front springs, panzer plate, pp520 injectors, RCII+, ASR
Aquaticmind is offline   Reply With Quote
Page generated in 0.16418 seconds with 10 queries
[Output: 89.56 Kb. compressed to 76.10 Kb. by saving 13.47 Kb. (15.03%)]
