Old December 16th, 2009, 19:41   #1
Tarbe
Default Joined the Mafia Today
'09 has 32k miles.
Leaving Friday for Virginia.
New filter and M1 ESP Formula M 5W-40 along for the ride.
Couldn't get myself to wait until 40k. Couldn't even get myself to wait until I got back from Virginia.
Tim
Two VWs sold back...see 'ya later. Maybe...
Tarbe is offline   Reply With Quote
Old December 17th, 2009, 06:57   #2
mdoaw12i
should be 5w-30 Mobil 1 ESP
09 JSW TDI- DSG/Black
mdoaw12i is offline   Reply With Quote
Old December 19th, 2009, 19:05   #3
Tarbe
Maybe in your car....
BTW - I have 1,100 miles on this oil change and my first two tanks have averaged 46.5mpg. Only assignable cause for the increase (that I have identified) is the oil.
I think several others have reported an increase in fuel economy with the Mobil oil. Nice side benefit if it holds up!
Tim
Old December 19th, 2009, 19:40   #4
Drivbiwire
Zehntes Jahr der Veteran
I personally don't see an issue with the M1 5w40 Formula M version, afterall it's what I use
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old December 20th, 2009, 01:39   #5
hid3
Banned
In a PD, CR or VE...?
hid3 is offline   Reply With Quote
Old December 20th, 2009, 08:32   #6
Drivbiwire
CR, I have also seen the aftermath of 5w30 in the PD engines and now recomend to all my customers the use of M1 TDT 5w40.
I have a PD that came in with catastrophic cam and lifter failure at 120K. Car just turned over 240K (comes in tomorrow) and going stronger than ever.
I also installed on the PD motors the Dieselgeek By-Pass to add to the protective margins of the M1 5w40 as well as 1 micron filtering.
Old December 20th, 2009, 09:59   #7
hid3
Banned
Nice! Will you be inspecting it for cam & lifter wear again? Please report the results back with what you'll find during the inspection! Thanks.
Old December 20th, 2009, 12:28   #8
Zambee500
M1 TDT 5w40 or M1 ESP-Formula M 5w40? I'm confused on which is the better of the non-505.01 oils that folks here are using.
And how do they compare to the 505.01 5w40 oils offered by Pentosin and LubroMoly?
2005 Passat GLS TDI (sedan)
Zambee500 is offline   Reply With Quote
Old December 20th, 2009, 12:31   #9
MyWifesTDI
Joined the mafia yesterday as well, my wife's '04 PD is running with Mobil Delvac 1 ESP 5W-40. Contemplating the use of ZDDP additive to bolster the Delvac 1.
MyWifesTDI is offline   Reply With Quote
Old December 20th, 2009, 12:54   #10
Zambee500
I'm totally confused again on the best M1 for a PD motor. I thought from this thread that M1 Delvac ESP 5w40 was not preferred over M1 ESP Formula M 5w40 or M1 TDT 5w40:
http://forums.tdiclub.com/showthread...=217700&page=3
Old December 20th, 2009, 13:17   #11
MyWifesTDI
Don't be confused, I am taking a path that I think is best for my vehicle. From what I have read, the the 5W-30 505.01 oils may not protect as well as the 5W-40 CJ-4 oils. I plan on using the Delvac 1 5W-40 and possibly running extended OCIs. That would require Oil Analysis to verify the oils (continued) ability to do it's job. Delvac 1 ESP is designed for OTR diesels with OCIs of 100K miles possible. The fact that others prefer M1 TDT 5W-40 based on UOA evidence, and M1 ESP Formula M 5W-40 having the MB 229.51 approval is their choice. Ohters have run Delvac 1 ESP with good results, they just are not in the majority. Whoever on this forum said, drive more, worry less, is absolutely correct!
Old December 20th, 2009, 14:20   #12
Drivbiwire
I would be the one who coined that phrase years ago...
Drive more worry less, DB
Old December 20th, 2009, 15:51   #13
MyWifesTDI
I have a similar saying on my mountain bike stem bolt cap which is a circular, and sentence reads: "All work and no play is on good at...". Repeat as many times as necessary.
MyWifesTDI
2004 Jetta GL (Jill) 2002 Jetta GLS Variant (Mike)
All work and no play is no good at all...anonymous
Old December 20th, 2009, 16:48   #14
adjat84th
adjat84th's Avatar
Bought a case of the Mobil1 5w30 ESP when we purchased the car new. Would it be in the motor's best interest to switch to the 5w40 Formula M after I deplete my remaining 8 liters of 5w30? Not really worried about the 5w40 being non 507.00 oil as it seems (at least from what I've read here) to be better suited for our applications in the long haul and is also DPF safe.
'01 Jetta | 17/22, 3bar MAP, 11mm IP/Lift pump, PD 150, OMI, FMIC, PP502s, SBC st3, .685 5th, Malone Stage 5
'15 Golf | GTD1752vrk, 4bar MAP, CP3, Peloquin LSD, DC stage 3 w/ SMF, Fluidampr
Old December 20th, 2009, 17:27   #15
Drivbiwire
I'm of the opinion that all VW engines require a 5w40. A 0w40 would be great also but are hard if not impossible to find in low SAPS formulations.
I won't run a 5w30 in any of my cars. I have tried it and I was not impressed with the wear rates.
Page generated in 0.11214 seconds with 10 queries
[Output: 122.38 Kb. compressed to 101.50 Kb. by saving 20.88 Kb. (17.06%)]
