perroni123
No boost at all can’t find the problem
Recently my car stopped making boost. Prior to my problem I installed new vnt15, actuator and n75. It worked great for a month but then I started getting codes for overboosting. Supposedly I was boosting at 30lbs....but I got the readings from a very cheap boost gauge. Now my turbo is making a realllly high pitched sound. I took off the down pipe and the inlet pipe. turbines are both spinning freely and barley any play. I’m not smoking a lot but I do also placed .216 injectors so it’s natural to smoke a bit at idle. I showed my tuner the sound and he said it’s a massive boost leak...I spent a saturate trying to figure out where this leak was everything seeems tight. I even took off the intake mani and the sound was still there. It sounds like it’s coming from the turbo internally. Did I blowup the turbo???
