05JTDI
I completed a 1" lift on my 2005 Jetta TDI about a month ago and I wanted to share how I approached the lift and provide some before and after measurements.
From the start, my goal was to use as minimal lift as possible to fit General Grabber AT2 tires in the 205/75/15 flavor (27.1" diameter). I had read many of the lift threads, including the Beef on Budget thread, and decided to aim for 1-1.5" of lift using a combination of MOOG 81134 front springs, 81055 rear springs, and aluminum strut spacers. I wanted to avoid using spacers in the rear and use the shortest spacer possible in the front in order to retain the majority of my strut travel.
Below are pictures of the front and rear MOOG springs together. Note that they are essentially the same length. The other two pictures are a comparison of the factory springs and the MOOG springs. The spring specs are as follows:
MOOG 81134: 14" long, 0.518" wire diameter
Factory Front: 14 1/8" long, 0.502" wire diameter
MOOG 81055: 14" long, 0.502" wire diameter
Factory Rear: 13 5/8" long, 0.450 " wire diameter
Front and rear Moog springs
MOOG front versus factory front
MOOG rear versus factory rear
The spring install was simple and has been documented in other areas so I will not go into detail here. For the rear springs, some people complained about the springs rubbing/making noise. The key is to get the tight winding on the bottom of the spring to rest in the front of the lower bucket, closest to the axle. This takes patience to get both springs in correctly because you have to have the axle in the right position and bend the springs so they are slightly curved to engage the upper cone extruding from the body and the lower bucket. You can see the spring properly placed in the driver's lower coil bucket below.
Properly installed rear MOOG spring
For the front, I knew I would need some amount of spacer since the MOOG and factory springs were similar in length and wire diameter. I ended up making 1" long spacers out of 1 3/8" x 1/4" wall 6061 aluminum tubing as shown to match the height of the rear. The spacers install in between the coil plate and the strut bearing.
Strut spacers
Strut spacers and MOOG coil spring installed
Now for the important details. With the stock springs and and very worn 195/65/15 tires, my front fenders heights were 26 1/4" and 26 1/2" and my rear fender heights were 26 3/4" and 27". After the spring and spacer install (no driving miles on the springs), my front fender heights were 27 3/8" and 27 5/8" and my rear fender heights were 27 7/8" and 28".
Summary
The MOOG 81134 front springs only gave me 1/8" of lift and I added another 1" using strut spacers.
The MOOG 81055 rear springs gave me about 1" worth of lift.
Stock suspension and stock tires
Lifted suspension and stock tires
Strut spacers
Summary
