ItsADiesel
Vehicle info..... 2002 Jetta TDI 192k miles
Hey guys, I recently started noticing that my brakes will occasionally fade as if they are overheated; though I know for a fact they aren't. It's like I'm losing my power brakes. Also, sometimes I feel like my car isn't making much boost and other times it's boosting just fine (No boost gauge so I can't give you exact numbers). Last thing, when I'm driving my car and I pull up to a light, I can faintly notice something that feels like a misfire or like my clutch is chattering, but it's not. Don't know if all of these issues are related....
My first thought was that my vacuum pump is going out and upon further visual inspection I saw there is a decent leak seeping out from under the vacuum pump.
I have a few questions......
1. Should I replace the entire vacuum pump or just the seal?
2. Is there somewhere else I should look for a vacuum leak?
3. Could a failing vacuum pump cause these issues or am I looking in the wrong place?
Thanks, as always!
-Fred-
Thanks, as always!
-Fred-
