Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old June 29th, 2018, 19:11   #1
CowboyCVW
Default Am I just being paranoid
so I have had my 2015 jetta TDI since august. At first I was a bit concerned as MPG was lower than expected but i found the car does better in cooler outside temps. Fast forward now and im finding that once outside temp is above 95 my jetta is running sluggish on acceleration,and im all of the sudden struggling to get 40 mpg at best on my daily 100 mile highway drive. Judging by the 1000rpm idle the car seems to be going into regen more often and if I shut down when I get home the fan is running. Changing the air filter last night I went check the dipstick and immediately smelled diesel. I know soot and a little fuel can get in the oil on a diesel but comparing to my ford powerstroke its never that noticeable.
Im curious if I should be concerned here. Anyone else with a Mk6 post fix vehicle seeing degraded performance and MPG in hot outside temps?
CowboyCVW is offline   Reply With Quote
Old June 29th, 2018, 20:19   #2
iamatt
iamatt's Avatar
Fuel Economy: 45
Straight pipe and tune. Get rid of that vw fix software and enjoy the car.
Sent from my FRD-L14 using Tapatalk
2014 Jetta TDI sedan (new) ,2014 TDI Jetta Sport Wagon 6MT (Flooded) Amsoil HDD3000 20K OCI, GSP Mod (RIP Rosie 4/4/2015), 2011 Toyota 4 Runner SR5 (Flooded), 2007 Duramax (Flooded), slightly modded GSPv2 is here, Bellatrix "Bella" Hunting God's County, katygsp.com
Amsoil Dealer -
http://www.texas-synthetics.com
iamatt is offline   Reply With Quote
Old June 29th, 2018, 20:22   #3
CowboyCVW
Im at least going to let the factory warrant run out first before i start modding the car. Are there any 2015s deleted that have anought mileage out there to know if this build will hold longevity like past cars? that 12 year 162K warranty is the other thing that has me hesitant to delete.
Old June 30th, 2018, 08:36   #4
tdi54
Something is not right. 2015 TDI's are quite
efficient. Without trying you should get upwards of 40 miles if not more. I have bought mine in March 2018 and did not
experience FE reduction in hot weather.Mine does regent at about every 250 miles I think. If yours is more often than this interval, that may need to be looked into.
I wish I could help you, hopefully other members will chime in.
tdi54 is offline   Reply With Quote
Old June 30th, 2018, 15:05   #5
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2018 to end of April 2019
My Passat will have the fan running if I shut the car off during a regen cycle. But I have a Scangauge II plugged into the OBD II port and have two gauges that tell me the temperature of the exhaust. If I see it is 1,200 or so degrees I wait with the car idling until the temperatures are around 400 deg before I shut down. Only takes a few minutes.
If you shut down during a regen cycle it will do that when you restart again.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar.
Old July 1st, 2018, 09:28   #6
goodmonkey
goodmonkey's Avatar
I'm using VAG DPF app and it seems I'm going through a regen every 250 miles or so with my '14. In the afternoons however the fans are running quite often when I shut down, but it isn't EGTs or DPF temp that are causing it, rather the coolant temp is 218F or so as read through Torque. Things are just that hot.
While VCDS is a great tool with smartphones it is worth having a Bluetooth OBDII scanner (mine was about $20 IIRC) to help answer some quick questions like these before taking it in or grabbing the VCDS and laptop out.
2014 Passat TDI SEL (DSG) - 78k, 2007 Silverado Duramax - 425k
Previous TDI's: 1996 Passat TDI- totaled at 394k miles, 1998 Passat TDI - 175k miles, 2012 Passat TDI SE - 41k, 1996 Passat TDI Variant - 327k, 2014 Jetta SportWagon TDI 6MT - 29k, 2015 Passat TDI SEL - 18k, 2006 Jetta TDI 5MT - 261k
goodmonkey is offline   Reply With Quote
Old July 2nd, 2018, 10:15   #7
r4ndys1ngh
I have a 2012 & got the fix done. I have noticed the EGT will spike from 230 Celsius to 720 max & drop down at random times when driving around.
r4ndys1ngh is offline   Reply With Quote
Old July 2nd, 2018, 16:02   #8
KERMA
KERMA's Avatar
are you tuned
HP is for show, TQ is for go.
celebrating 15 years of: http://www.kermatdi.com
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old July 2nd, 2018, 16:37   #9
forrest resto`s
I'm somewhat confused.. all the 40+ mpg's claimed.. is anybody saying this is strictly hwy. careful driving miles?? I hope y'all will be more definitive in your "mpg's" cause I really believe most people aren't getting 40+ mpg's just driving around...Thanx for clearing this up for the "novice's"... I have 4 of these tdi's.. and you if you drive these like most drive their "Honda's or Toyota's" you will not get 40+...
forrest resto`s is offline   Reply With Quote
Old July 4th, 2018, 19:45   #10
CTD_Chevrolet
CTD_Chevrolet's Avatar
Fuel Economy: 2015:46 Highway 26 City - 2002: 42 Highway 28 City
I get garbage mileage in town but yeah highway I get 45-46 consistently. My highway low is ~41 and that's only happened a couple times. When it's under 44 I start wondering what's going on. City, on the other hand, is all over the place, high 20s to low/mid 30s, which I partially attribute to aggressively massaging the throttle to mitigate the emissions/dsg tuning.
My highway speeds are 70-80 depending on where I am. Most of the miles are driving between southwest MT and the bay area in CA. I've broken up the drive different ways to see how much of a difference terrain makes but I haven't noticed any big differences. I keep telling myself I'll figure out how much speed influences it but every time I decide I'd rather get there an hour earlier than find out.
Edit:
I have one high temp datapoint: 547 miles from Wells NV to the north bay, 44.92mpg 95+ degrees AC cranked the whole way (paraphrasing the note I took). Most of that would be 70-80 slowing down in the end but going through rougher terrain.
Edit 2:
I got confused and thought I was applying to OP but my comment is relevant to both
'15 Jetta S DSG - New old stock, 30% tint, 1 sticker
'02 Jetta 5 spd - 17/22, Race 520s, 11mm pump, ARP studs, 3" straight pipe, SBC Stage 2 Endurance w/secret sauce plate and 14lb SMF, Kerma Tuning, tons of stickers
'95 Chevy K2500 Brodozer - P Pump Cummins, NV4500, Dana 60, most stickers
CTD_Chevrolet is offline   Reply With Quote
Old July 5th, 2018, 06:41   #11
NewYorkBuck
NewYorkBuck's Avatar
I have a 2015 with over 80k. On the highway, I get 48-49, hand calculated. Around town and highway mix, I get 42-44.
I calculate my mileage almost every tank, and I have never carded below 40.
2005.5 VW Jetta TDI (traded in at 112,500)
2015 VW Jetta TDI
2004 Porsche 911 Turbo
NYC Subway
NewYorkBuck is offline   Reply With Quote
Old July 9th, 2018, 12:29   #12
r4ndys1ngh
Originally Posted by KERMA View Post
are you tuned
I did have the malone stage 2 but it got reflashed to stock when I did the emissions recall.
Old July 12th, 2018, 07:57   #13
chaoscreature
chaoscreature's Avatar
Fuel Economy: Good Enough
Is no one else concerned about the heavy diesel smell in his oil? My oil is gross black immediately on my mk5 and mk6 tdi, but has never smelled like diesel.
"If everything is under control, you are going too slow." - Mario Andretti
2006 Jetta TDI Special Edition
chaoscreature is offline   Reply With Quote
Old July 16th, 2018, 09:47   #14
Rodmiser
Fuel Economy: sorry last tank 44.2 MPG
Try 550 miles per fill ups?
Rodmiser is offline   Reply With Quote
Old July 17th, 2018, 04:37   #15
tdiinsc
Granted i dont have much experience in the TDI world, but mine with phase 2 fix started to regen more than my wifes golf sportwagen (hers with phase 1 only). I noticed that if once a day i really give it the beans it reduces the amount of regens. Mine would typically be in a regen cycle the minute i got home from work. After adjusting how i drive it, i havent noticed it at all.
Someone correct me if im wrong, but regens will occur when the soot level in the DPF reaches a certain level. Driving the car easy may contribute to more frequent regens. Its possible that the threshold was lowered to encourage more regens to save the DPF from getting clogged up. Sorry if my frequent use of the regens is annoying
Oh yeah forgot to add, its hot as balls in Greenville.....typically at least 95 every day when i drive home from work.
tdiinsc is offline   Reply With Quote
Paranoid ? ottomatic Dieselgate - VW Group Emission Scandal 25 January 14th, 2017 08:37
Paranoid? HBRD_KLR VW Passat Family (NMS and B7) TDIs (2012+) 52 July 16th, 2014 08:23
Am I Paranoid? Palladin VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 April 14th, 2013 14:19
Help! Am I being paranoid? GotDiesel? VW MKIV-A4 TDIs (VE and PD) 6 July 16th, 2001 08:54
for the truly paranoid famous VW MKIV-A4 TDIs (VE and PD) 29 June 9th, 2000 22:53
Page generated in 0.16077 seconds with 12 queries
[Output: 132.08 Kb. compressed to 110.47 Kb. by saving 21.61 Kb. (16.36%)]
