ninedee_golf_tdi
I'm troubleshooting code 01276 ABS Hydraulic Pump V64 Signal Outside Tolerances. In the Bentley trouble shooting matrix in the "T" section (starting at T-01-53), I'm supposed to perform steps 15, 27, 35 and 36. The car is a 07/94 glx b4v.
step 15 (winding resistance of ABS hyd pump relay J185) Ok
step 27 (resistance of hyd pump sensor G101) no reading at all, like the circuit is open
step 35 (function of ABS hyd pump v64) Ok, pump runs as it should
step 36 checks edl function, not performed yet
My question is, is the G101 sensor available and replaceable ? Where is it located on the ABS pump ?
Any other ideas to get this going ?
Thanks.
Thanks.
