oldpoopie
- Joined
- May 14, 2001
- Location
- Portland Oregon
- TDI
- 2001 golf gl, 2006 jetta, 1981 ALH swapped rabbit pickup, 1998 beetle
Ok. So here is the deal... again....
Car is 99.5 jetta.
about 125k on the odo
New n75
car throws cel, then eventually goes to limp mode.
cel reads:
17958 - Charge Pressure: Control Deviation
P1550 - 35 - 00 - -
The code sometimes says intermittent too.
Tonight I replaced ALL of the vac hoses, and replaced the EGR/antishudder valve assembly with a clean fresh unit. This did nothing, and the car still does the same thing. While changing the egr, I did see the obvious need to clean the intake, and I will be doing that.
Now, some more observations. While driving the car around for a test with the windows open, the turbo made a peculiar noise. Normally, when you floor it, and the car builds boost, and you let off really fast, you can hear the turbo spool down quickly, and it makes a quiet noise like, "PEEEeewwwwww......." that kinda trails off smoothly. Well, this car is making a noise like, "PEWEWewewewew......"trailing off. The intake is really clogged, and its my last stop before telling this guy he's gonna have to spring for a new turbo. Has anyone ever run into anything like this before?
Here's a shot of the intake.
and a shot of the egr that was replaced.
I'm wondering if the intake could be so clogged that its causing this CEL and boost deviation.
Car is 99.5 jetta.
New n75
cel reads:
P1550 - 35 - 00 - -
