Hey Jimbote, I'm doing a very similiar swap, and am having a few issues with wiring. I'm using an ALH as well, and when i pulled the the engine i basically left anything engine harness related attached to the engine. Do you have any good pictures of what circuits/branches you kept from the body harness (if any)? Or did you just create your own body side harness to interface with the T10 connectors in the "protective housing for connectors, in plenum chamber" and the T14 connector etc. I am tyring to re-use as much VW harness as possible, I have the Bentley manual but just looking for someone whos done this swap's opinion. Thanks in advance
