Old October 23rd, 2006, 16:52   #1
rix337
rix337's Avatar
TDI(s): 09 Jetta TDI
Default Timing Belt may have jumped a tooth?
Is there a way I can tell for sure with a Vag or do I have to take the covers off? It seems to run okay but it is smokey. Starts horribly in cool weather(40-60F). I have checked the injection timing with the Vag and it is dead on. Did the intake cleaning about 20k ago and adjusted the EGR cycle as suggested in this forum. Also checked the glow plugs even though they aren't used at these temps. Any help would be appreciated.
2001 Jetta TDI GLS
116,000 miles
timing belt done at 73,000 miles.
MAF also replaced at that time.
No CEL's at this time.
rix337 is offline   Reply With Quote
Old October 23rd, 2006, 21:37   #2
rix337
rix337's Avatar
Old October 24th, 2006, 07:11   #3
alphaseinor
You should check the static timing, this is different than the VAG timing, as it's a physical "the crank is in this position, and the cam is in this position".
Is the timing "dead on" as in advanced, or retarded?
alphaseinor is offline   Reply With Quote
Old October 24th, 2006, 08:11   #4
rix337
rix337's Avatar
I don't have the actual numbers I was getting but it was a little on the high side of the middle of the graph in my service manual, so I think that is very slightly advanced. Also, when I checked the timing I did check the temp sensor and it was reading ambient temp before I started the car, so it should be ok. And I am located in Atlanta, Ga. Someone suggested I put this info on here.
Old October 24th, 2006, 08:15   #5
rix337
rix337's Avatar
Can I check the static timing with the Vag-com?
Old October 24th, 2006, 08:28   #6
rdkern
Fuel Economy: A4 = wife drives it, don't know
The suggestion was to actually line up the various items in the engine compartment and make sure all is where it should be. This is done prior to the VagCom checking.
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old October 24th, 2006, 09:23   #7
rix337
rix337's Avatar
Ok, no problem. I will dig into checking that when I get home. I just thought there might be a way to tell it on the Vag-Com. So if it has jumped, it wouldn't necessarily show up in the info found with a Vag-Com such as the inj timing, etc?
Page generated in 0.15629 seconds with 10 queries
[Output: 76.26 Kb. compressed to 65.76 Kb. by saving 10.50 Kb. (13.76%)]
