Old May 19th, 2006, 14:03   #1
kart17
Fuel Economy: 39 City -52 highway
Angry Timing Belt appears to have jumped
Hi Everyone!
OK here is my situation. 99.5 Jetta TDI ALH, manual tranny. TIming belt, water pump, tensioner, etc all replaced by dealer < 5K ago.
Driving along, fell a slight shudder, and car shuts off. Attempt to re-start while clutch is in, it cranks but wont fire. Look over everything, check battery, fuel filter, then notice no accessory belt!!!! See pieces but thats it. Try to crank, it turns but wont start.
Pulled off upper timming belt cover, pieces of twine floating around under gears etc. Not a ton but more then I would like to see.
Set flywheel to TDC mark. Pull vacum pump and check cam slot for horizontal position on head deck, looks good. Check injector pump, and it apears the pump gear is off 30-40 degrees!!!!!! Slot in pully is around 11:00 looking at the pully.
(Didn't check for "lobes up" on cam position on cylinder 1 yet as didn't wnat to buy new valve cover).
Timing belt looks ok.
Is there an easy way to get things back in sync besides:
loosening tension pully, pulling valve cover off and checkiung lobes up, locking down cam, pulling cam gear, taking belt off injector pump gear, syncing things back up and putting it all back together?
Thanks in advance,
Kart
kart17 is offline   Reply With Quote
Old May 19th, 2006, 14:41   #2
GoFaster
Moderator at Large
Wrong forum, you have an A4 not an A5 ...
But anyway, getting it back in sync is the least of your worries. With the cam timing that far off, it is practically a certainty that you have had valve/piston collisions. Take the valve cover off, take the camshaft off, and note which valves have lifters that aren't coming up as high as the highest one ... those are the smashed-up lifters. Any valve associated with such a smashed-up lifter ought to be replaced, and that means the cylinder head has to come off. If you don't see any smashed-up lifters, perform a cylinder leakdown test (NOT a compression test - different). Excessive cylinder leakdown at this point means bent valves. Again, the head needs to come off.
You might as well figure on taking the cylinder head off, see what's damaged, and go from there. Anything that has taken a hit, whether it looks OK or not, needs to be replaced.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old May 19th, 2006, 14:42   #3
TDI 4 RD
TDI 4 RD's Avatar
Fuel Economy: ~38 mpg (first tank); 41.2 (second tank); now averaging ~42 mpg.
Although I'm sure someone in this forum will help you if they can, you may have better luck posting this in the A4 model discussion area or in the appropriate engine discussion area. This forum is for the new MKV models. Good luck.
.....oops, sorry GoFaster.
2006 Jetta TDI (build date Oct. 2005). 185000 miles. Mods: Euro LED Tail Lights, Amber Mode; Rear Fog Light; Aspherical Mirrors (Blue Tint); Osram SilverStar Hi/Lo Beams; DieselGeek SkidPlate; Hella Dynabeams; TDIFrostheater. Best Tank: 632.9 miles on 11.8 gallons = 53.6 mpg (06/08; cruise control set at 65 mph for most of the tank). Member of the 700 club (04/23/08).
TDI 4 RD is offline   Reply With Quote
Old May 19th, 2006, 14:43   #4
GoFaster
Moderator at Large
By the way, you ought to go back to the dealer that did the timing belt job. Be prepared for resistance (because of the EXPENSIVE bill that this is going to run up) ... they may try to tell you the failure was because of something else. BULL. It's because they screwed up the job. They owe you a repaired engine.
Brian P.
Old May 19th, 2006, 14:50   #5
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
>>TIming belt, water pump, tensioner, etc all replaced by dealer < 5K ago<<
Another sad first post... (in the wrong section, but I imagine the OP is a bit upset...)
I'm afraid this is yet another Dealership Timing Belt Success Story...
Please update your profile to indicate your location... you may need the assistance of a veteran TDI owner... you're in for a major league argument with the dealership... in any case, it's under warranty, but getting them to admit that they did anything wrong may not be easy...
Good Luck!!!
Yuri
ymz is offline   Reply With Quote
Old May 19th, 2006, 15:40   #6
kart17
Thank folks! Have reposted in other A4 Forum. Sorry for the wrong post.
Old May 19th, 2006, 16:50   #7
ymz
Nearest Super-Guru to you would be Matt Wallen (UserID "Car 54") here... Please try to get in touch with him, although he's in Woodbridge... it may be worthwhile having him come down to look at the car / consult with the dealer on your behalf...
Good Luck !!!
Yuri.
Old May 22nd, 2006, 18:34   #8
Faster
Fuel Economy: 48-53mpg
I've seen my share of damaged engines due to botched belt jobs but I've also seen a few survive a one-tooth jump with no problems.
Installing a new belt and turning over by hand will tell you if there was major damage. That said, pulling the head isn't hard - just time consuming.
--Faster
Page generated in 0.16435 seconds with 10 queries
[Output: 81.59 Kb. compressed to 69.92 Kb. by saving 11.67 Kb. (14.31%)]
